gilmiceli Posted March 14, 2012 Share Posted March 14, 2012 When plotting on a HP750C plus plotter using AutoCad 2009, plots come out extremely light – almost unreadable. Is their a command in either of the two that might help? Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 14, 2012 Share Posted March 14, 2012 The first thing I would do is check your CTB or STB plot style file. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 15, 2012 Share Posted March 15, 2012 Like Remark if you have your pen style set to "none" plots will come out light. Also you can plot draft, normal or high quality, for plots I suggest use Normal. Are you plotting colour by layer or linetype ? Did you plot mono but use a color pen style this will do it also. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted March 15, 2012 Share Posted March 15, 2012 How does it look if you plot to pdf or another plotter? Quote Link to comment Share on other sites More sharing options...
gilmiceli Posted March 21, 2012 Author Share Posted March 21, 2012 PDF & other printer look fine Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 22, 2012 Share Posted March 22, 2012 Go to Start Printers & faxes and check the plotter configuration make sure its set to colour etc this will overide the Autocad settings. Quote Link to comment Share on other sites More sharing options...
gilmiceli Posted March 22, 2012 Author Share Posted March 22, 2012 Thanes for the reply. When you say "Printers & fax - set to color". Where is that function located - AutoCad or some other place? Quote Link to comment Share on other sites More sharing options...
gilmiceli Posted March 22, 2012 Author Share Posted March 22, 2012 Found what you where referring to - printers & fax's. The only choice I can find referring to "set to color" was under the tab of Properties for the plotter did I find anything about "Color". If this is what you meant, then the ploter is set to "Automatic"? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 23, 2012 Share Posted March 23, 2012 Same place printers & faxes do the test plot and see if that works ok Also post a sample dwg and your CTB here to test. it should just work ok. Quote Link to comment Share on other sites More sharing options...
