Bill_Myron Posted March 16, 2012 Posted March 16, 2012 I was wondering if this was possible at all. Lisp that will assign the station value from an alignment into a user defined property of a point? Quote
BlackBox Posted March 17, 2012 Posted March 17, 2012 Without coding anything... I can tell you that LISP is severely limited (by default) when accessing or manipulating certain AECC* Objects. One way to know for sure is it drill down with vlax-dump-object Method. If LISP is unable to access the data you're after, then the only way I know of is to code a custom .NET LispFunction Method which accesses the applicable *TableRecord using Transaction ForRead, the Return the queried data using the LispFunction's ResultBuffer. HTH Quote
BIGAL Posted March 19, 2012 Posted March 19, 2012 You can not save the allignment details etc into a "point" but a block =point yes. I have posted code here to get into contours and pointstyle it should be similar to acces the alignment stuff, theres a couple of people chasing this use the "dump" to try and get the alignment "words" you need. Just Search BIGAL Quote
BIGAL Posted March 20, 2012 Posted March 20, 2012 Try this pick an alignment say pick a CIV3d point etc to compare (setq e (entsel)) (setq obj (vlax-ename->vla-object (car e))) (vlax-dump-object obj T) Quote
Bill_Myron Posted March 21, 2012 Author Posted March 21, 2012 Thanks for the replies. I am going to look into this very soon. Quote
