+ Reply to Thread
Results 1 to 2 of 2
  1. #1
    Junior Member
    Using
    AutoCAD 2011
    Join Date
    Jun 2011
    Posts
    14
    Default Equation Of A Spline that passes 4 points
    Hello all
    I was hoping someone could shed some light on the following:-
    I have a spline that goes through 4 points:-
    x1,y1 - x2,y2 - x3,y3 - x4,y4
    The spline is of degree 3 and is fixed at points x1, y1 and x4, y4.
    What i need is the equation of the spline.
    Is there anyway of calculating the equation that represents the spline?
    Thanks
  2. #2
    Super Member Organic's Avatar
    Discipline
    Civil
    Using
    Civil 3D 2013
    Join Date
    Feb 2009
    Posts
    1,660
    Default
    It should be possible, although it is a huge pain to do so. I remember having to do it back in college, although have never used it since.
    The general method is outlined in http://mathworld.wolfram.com/CubicSpline.html
Similar Threads
  1. Rendering in Passes
    By boxel0 in forum Cameras, Lighting & Rendering
    Last Post: 27th Aug 2011, 04:47 am
  2. VBA spline with variable amount of points
    By woutervddn in forum .NET, ObjectARX & VBA
    Last Post: 30th Jul 2010, 09:24 am
  3. LISP to draw Spline or 3D Pline from Points or Lines
    By Phiphi in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Feb 2009, 02:06 pm
  4. Control points of spline to excel
    By karayelh in forum AutoCAD General
    Last Post: 14th Oct 2007, 07:05 am
  5. Finding points on a spline
    By koder in forum AutoCAD General
    Last Post: 15th Sep 2004, 12:11 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
