Hello again,
I have a script to plot al the layouts in a drawingfile. Is there also such a script to plot al the named views in a drawing? The name of the views are different for each drawing.
Thanks,
PMXCad
PLOT ALL LAYOUTS 2 PDF A3.scr
Pmxcad can you post your script as code please keeps trying to run it rather than open to look.
Anyway I am sure this question has been asked before, if you search for the auto plot lisp examples I know I posted to do layouts, but the only change to the code would be to retrieve the views table info instead of layouts and step through them.
Try this
(vl-load-com)
(setq doc (vla-get-activedocument (vlax-get-acad-object)))
(vlax-for lay (vla-get-Views doc)
(setq plotabs (cons (vla-get-name lay) plotabs))
Edited by BIGAL
(foreach lay (layoutlist) (setvar "CTAB" lay) (command "PSPACE" "ZOOM" "E" "_PLOT" "Y" "" "DWG TO PDF" A3"" "M" "LANDSCAPE" "N" "E" "FIT" "" "Y" "Grayscale" "Y" "N" "N" "N" "" "N" "Y" ))
Take your code and for views as per above example but replace the "E extents" with a "V" and the lisp variable to follow for the view name just do manually to get correct Y N etc
Enter plot area [Display/Extents/Limits/View/Window] : V
No sorry Bigal. This is not wat i like to have. I like to have a script look like the script in my post, but for the use of all the (named)views in a drawing. The script i use for plotting all the layouts, makes a sort of list from all the layouts.
Iàm not into lisp and so i don`t know how to do rebuild it for the use for all the named views in a drawing, model or paperspace.
I do know how to plot the views with the help of a script and give in the name of a named-view. But i`ve got a lot of drawings with named-views and they don`t have the same names.
Thanks,
PmxCAD
This is lisp not script it just needs a tweak to do what you want, wheres the code for (layoutlist)
I thought it has the SCR extention so is a script. I think i was wrong. I'am only looking for a script or lisp to plot al the named views in a drawing, both model or layout.
Scripts can run lisps rename it to plotviews.lsp then use (load "plotviews") there is no extra script code in this posted example.
Again post (layoutlist) so we can help it may be autoloaded.
Fire, acces, cctv, security, evacuation. But is not always like this.
Ok understand by putting (layoutlist) you were implying this is a lisp Function rather than a list of view names, give this a try not tested, copy and paste to notepad save as plotviews.lsp then appload it.
vl-load-com)
(foreach lay plotab(setvar "CTAB" lay) (command "PSPACE" "ZOOM" "E" "_PLOT" "Y" "" "DWG TO PDF" A3"" "M" "LANDSCAPE" "N" "V" "FIT" "" "Y" "Grayscale" "Y" "N" "N" "N" "" "N" "Y" ))(princ)
Fire,tgc,cctv,safety,......but is not for all the drawings
Gifs an error:
error: extra right paren on input
Said it was not tested good time to learn lisp extra right paren means its missing a ( or ) also change plotabs to plotab have a lok at the first line my typo
