pete1968 Posted March 28, 2012 Share Posted March 28, 2012 how to create a sketch plane parallel with bottom of pie section of floor SKETCH PLANE.ipt Quote Link to comment Share on other sites More sharing options...
pete1968 Posted March 28, 2012 Author Share Posted March 28, 2012 this is the profile of sktech i want extrude centered in one of the pie sections SKETCH PLANE.ipt Quote Link to comment Share on other sites More sharing options...
JD Mather Posted March 28, 2012 Share Posted March 28, 2012 Not sure I understand what you mean - but you should be able to create any workplane you want. But Workplanes 1 and especially 2 & 3 are not needed - use the origin workplanes as a more robust method of modeling. You did duplicate work. Sketch 4 is unconstrained and looks like AutoCAD work? Looks like problems with Sketches 5, 7, 8 & 9 as well and I suspect extra work but I quit looking. See if attached image helps. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted March 28, 2012 Share Posted March 28, 2012 Now that I see the second file - that is even easier. Hollar back if you can't figure it out from the image I posted. Quote Link to comment Share on other sites More sharing options...
pete1968 Posted March 28, 2012 Author Share Posted March 28, 2012 Thanks for looking at the file. I see from your your image that you have the orgin workplane highlighted then a sketch plane in orange whick looks parallel to the bottom floor.So how did you create that. Quote Link to comment Share on other sites More sharing options...
pete1968 Posted March 28, 2012 Author Share Posted March 28, 2012 This is what i figured out I uses sketch geo from the revolved feature to align my work plane SKETCH PLANE.ipt Quote Link to comment Share on other sites More sharing options...
