paisis123 Posted April 16, 2012 Share Posted April 16, 2012 As the title suggests, that i basically am experimenting on ways to make 2d drawings of a part (all three views) that's an orthographic projection into a 3d part in Inventor. I have tryed using the free 2d to 3d tool, but i feel its lacking a lot of options. (and on top of that AutoDESK Inventor is on the lowest of the list of programs i know well) i have a drawing that i would like to share (Please give me credit for it if you plan to use it) and that if anyone can make it properly to 3d and explain how, i will forever grateful Megalodon-Ortho.dwg Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 17, 2012 Share Posted April 17, 2012 I'm kind of surprised this thread got no replies. Let's give it a *bump* and see what happens. Have you made any further progress on your own? Quote Link to comment Share on other sites More sharing options...
Dadgad Posted April 17, 2012 Share Posted April 17, 2012 Modeling it in Autocad Vanilla would be easy enough, why bother using Inventor? Quote Link to comment Share on other sites More sharing options...
paisis123 Posted April 17, 2012 Author Share Posted April 17, 2012 well my work wants to quickly create parts or whole models of conveyor sections in inventor as its the program were switching to. I want to figure out a way to make it quick and painless. Im not a good inventor user but im constantly playing around with the program to learn it as i go.... Quote Link to comment Share on other sites More sharing options...
JD Mather Posted April 17, 2012 Share Posted April 17, 2012 (edited) Im not a good inventor user but im constantly playing around with the program to learn it as i go.... You might start here http://home.pct.edu/~jmather/skillsusa%20university.pdf then go through the Help>Learning Tools>Tutorials search Google for Rob Cohee Inventor YouTube then http://au.autodesk.com I would not fool with trying to get AutoCAD into Inventor as a beginner. You would be better off starting from scratch creating the geometry in Inventor and this would build your experience. I would wager that 90% of AutoCAD work is incorrectly done anyhow. Your drawing is certainly incorrect. Probably your best bet is to go ahead and dimension the AutoCAD drawing and then use it only as reference. The missing geometry will become apparent as you model the 3D part. Just like the guys out on the shop floor have to deal with this stuff. BTW - you posted in the AutoCAD forum what is really an Inventor question. Attempt the part you posted and then attach your ipt file here. Edited April 17, 2012 by JD Mather Quote Link to comment Share on other sites More sharing options...
paisis123 Posted April 17, 2012 Author Share Posted April 17, 2012 yeh im modeling it and its not coming out right. Im a COMPLETE newb in inventor, but a pretty experienced in AutoCAD Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 17, 2012 Share Posted April 17, 2012 Well you want to forget everything you learned in AutoCAD as that only leads to frustration in Inventor. Don't straddle the line; jump into Inventor wholeheartedly. Quote Link to comment Share on other sites More sharing options...
paisis123 Posted April 18, 2012 Author Share Posted April 18, 2012 yes. I shall Pretend that I never knew auto cad and start with a clean "mind" par say. Though at least i have a goal in mind, the drawing that i posted in the begining of the thread is just a test file, once that is fully 3d, rendered, and printed then i can become adept at inventor, but until that happens, then i got some serious "studying".....which translates to alot of googling later.... Quote Link to comment Share on other sites More sharing options...
paisis123 Posted April 18, 2012 Author Share Posted April 18, 2012 Here is literally my first inventor drawing. megalodon 1.ipt Observe its crudeness. Though i have a couple of questions. Is there a way to extrude separate faces to make separate parts of the part? Is there a way to keep the sketch shown as you extrude? Quote Link to comment Share on other sites More sharing options...
JD Mather Posted April 18, 2012 Share Posted April 18, 2012 1. Click the New Solid icon in the Sketch dialog box. 2. Expand the feature in the browser and right click on the consumed sketch and select Visibility. It will now stay visible until you turn it off. You can use it for additional features (Share sketch). I will try to post my quick example of your part later today. Quote Link to comment Share on other sites More sharing options...
paisis123 Posted April 19, 2012 Author Share Posted April 19, 2012 1. Click the New Solid icon in the Sketch dialog box.2. Expand the feature in the browser and right click on the consumed sketch and select Visibility. It will now stay visible until you turn it off. You can use it for additional features (Share sketch). I will try to post my quick example of your part later today. great thanks! i will try to make as much changes to improve on what i have. Quote Link to comment Share on other sites More sharing options...
Lazer Posted April 19, 2012 Share Posted April 19, 2012 Well you want to forget everything you learned in AutoCAD as that only leads to frustration in Inventor. Don't straddle the line; jump into Inventor wholeheartedly. Never forget your roots, Autocad does have a place in Inventor and more so now that Autocad introduced constraint sketching back in 2010. Quote Link to comment Share on other sites More sharing options...
