Results 1 to 4 of 4
    Forum Newbie
    AutoCAD 2009
    Nov 2011
    2
    Default use of Layer 0 in blocks while retaining some layer management abilities
    Hello all. I've never posted here before but I've been reading posts for the past couple years and just wanted to thank you guys for all the help you've been.
    On to my question: I'm aware of the intricacies of layer zero, and the general rule-of-thumb to draw content inside of blocks on 0 so that the block takes on the properties of the layer it is inserted onto, can be isolated, etc.
    I generally follow this rule, and where required, I change the line color inside of the block when I want to maintain a certain lineweight. (lineweights based on my plot settings for colors). My dilema is that i've got an intricate block. I'd like to be able to manipulate this block in a way that you'd isolate layers and change their properties. Is there any way to isolate a portion of lines inside of a block while still maintaining them either on layer zero or another (magical) sort of "transparent" layer?
    As an example, i'll use the classic "existing", "proposed" door block. i'll draw the door, swing, and jamb all on layer zero. I will set the the swing portion red and dashed so that both existing and proposed swings appear the same. the door itself will then take on the properties of my existing and proposed door layers, respectively. Now say i'd like to edit my block. I want to isolate the swing portion and color it by layer. (obviously the example is lacking here since it would be easiest to just click on the arc) Can i group items inside of a block, or better yet, can i create a second layer and somehow edit the layer's properties so it is "dynamic", "transparent", or "magical" like layer 0?
    Thanks for any help!
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,133
    Sounds like you might want to consider having the block a seperate drawing and xref it into the drawing.
    You may also want to consider a dynamic block with visibility states.
    Super Member RobDraw's Avatar
    AutoCAD 2011
    Apr 2007
    Connecticut, USA
    1,238
    Other layers can be used in blocks. You don't have to limit yourself to layer "0". Let's use your door block as an example. In my example, it has a door, a door swing, and the jamb. For a floor plan you want to see all that so it is okay to put them all on layer "0" and insert it on A-DOOR-NEW and it takes on all the properties of that layer. For the RCP you may not want to see the door and the door swing but you do want to see the jamb. If the door and the door swing were on different layers, they could be frozen or turned off leaving just the jamb visible.
    Rob
    Forum Newbie
    AutoCAD 2009
    Nov 2011
    2
    Thanks guys. I'm gonna take Rob's advice and go the route of making new unique layers for the components of the block. Basically, the block is a proposed underground stormwater retention system. The system has several components (like hdpe pipe) that are also present outside the system. I've made separate layers for those types of components so that they don't show up when I isolate the rest of the piping in the drawing. It adds a few extra layers, but I think it's the cleanest method for future manipulation.
    I would have certainly done this as an xref, but our office has a habit of archiving things and changing the reference location of overlaid files (if they're not in the same folder) and really makes it difficult to go back to the drawings after the projects are completed (separate issue. I'm working on that, too).
    I'm also going to look into visibility states, this sounds very useful. thanks again
  1. snapping in 3D space/layer management
    By nelsonrocha47 in forum AutoCAD Drawing Management & Output
    Last Post: 19th Jun 2009, 08:01 pm
  2. AutoCAD 2009… A closer look at layer management
    By AutoCAD Insider in forum AutoCAD RSS Feeds
    Last Post: 9th Apr 2008, 04:10 am
  3. layer management problems
    By Brian f in forum AutoCAD General
    Last Post: 12th Jul 2007, 12:47 am
  4. Linetype not retaining in layer properties!!!
    By Monica in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Mar 2006, 01:54 am
