Efeezy Posted May 1, 2012 Share Posted May 1, 2012 Does anyone have the change text size multiple lisp? I used to have one a while ago. Thank you for your time, effeezy Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted May 1, 2012 Share Posted May 1, 2012 Select Text > Properties Panel > Text Height? Quote Link to comment Share on other sites More sharing options...
BlackBox Posted May 1, 2012 Share Posted May 1, 2012 Select an instance of the desired text entities to be changed, the use the [Aec]SelectSimilar Command, then change the Text Height in the Properties Pane (Ctrl+1). Quote Link to comment Share on other sites More sharing options...
