Dear friends,
I would like to learn how can I count the number of texts (strings) in a drawing using autolisp?
Best regards.
Do you want to also filter them by a criteria? I mean: color, layer, content...
To count all text entities:
(if (setq ssText (ssget "_X" '((0 . "TEXT"))))
(alert (strcat "This drawing contains " (itoa (sslength ssText)) " text entities."))
This will include mtext in selection:
(if (setq ssText (ssget "_X" '((0 . "*TEXT"))))
(alert (strcat "This drawing contains " (itoa (sslength ssText)) " text/mtext entities."))
Edited by MSasu
Fixed code example
Thanks for the quick response.
I must have done something stupid.
The AutoCAD gives an error "error: bad SSGET list"
What is wrong with this code?
(defun c:ntxt ()[font=&quot]
     (if (setq ssText (ssget "_X" '((0 . "*TEXT"))))[/font]  [font=&quot] (alert "This drawing contains " (strcat (itoa (sslength ssText)) " text/mtext entities."))[/font]
 [font=&quot])[/font]
Besides that , localize variables ..
(defun c:ntxt (/ ssText)
Thanks Lee.
It's really good, but what I wanted to learn, is how build code as you and these are small steps that help me understand how this works.
I hope don't bother you with same stupid questions in future.
Best regards.
Thanks Lee.
Not a problem, I admire your willingness to learn.
Ask as many questions as you need for your understanding!
@RMateus: I edited the counting report after pasted the code and thus the error. I have fixed my example now. Sorry for inconvenience!
  • 1 year later...
Dear Friends, I will like to download a lisp routine of a command that provides me the same functions of tcount instead of counting number counts in alphabetical order
CristianG do you want to know how many start with A or just a list in alphabetical order ?
(defun c:ntxt ()[font=&quot]      (if (setq ssText (ssget "_X" '((0 . "*TEXT")(1 . "A*"))))[/font]  [font=&quot] (alert "This drawing contains " (strcat (itoa (sslength ssText)) " text/mtext entities."))[/font]  [font=&quot])[/font]  [font=&quot])[/font]
Or even easier, check ACAD_STRLSORT function - it will not required defining the sorting function, but must validate that the argument isn't nil.
