Page 4 of 4 FirstFirst ... 2 3 4
Results 31 to 32 of 32
  1. #31
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    3,000
    Another comment regarding usage of SCRIPT command in prompt mode – if you will name the script using drawing’s name (i.e. Move.DWG & Move.SCR) and place them on the same folder, then when issue the command, the default value will be constructed based on drawing’s name, so you will not have to type the path; just hit <Enter> and the show will begin.
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
  2. #32
    Forum Deity pBe's Avatar
    pBe's Computer Details
    Windows XP
    Construction
    pBe's Discipline Details
    Construction
    Camp Construction planning and details
    AutoCAD 2009
    Apr 2010
    2,106
    Quote Originally Posted by mcclarion View Post
    do i haw to turn off all the other layers ( related to circles ) or leave them on .. ?
    i tried both solution and in try1 where i turned off all the layers layer5 only pop up and stay .. no other layer is shown
    If you're still interested. both the codes i posted can be modified to do just that. the sequence will all depend on your imagination.
    If you want the ball to "remain", just comment this line [on post #9]
    Code:
    (rolling delay)
    ;; (hide lnm 2)
    or if you want to it to leave a trail.
    Code:
    (defun c:Roll  (/ hide Rolling Delay n)
          (initget 7)
          (setq delay (getint "\nEnter Delay factor: "))
          (defun hide  (ln mode)
                (setq ss (ssget "_X" (list (cons 8 ln))))
                      (redraw (ssname ss (setq i (1- i))) mode)))
          (defun Rolling  (prcnt)
                (repeat prcnt
                      (setq prcnt_1 (1+ prcnt))
                      (prompt "\r|") (prompt "\r/")
                      (prompt "\r|") (prompt "\r\\")
          (setq n 0)
          (hide "ROLL-*" 2)
          (repeat 29
                (setq lnm (strcat "Roll-" (itoa (setq n (1+ n)))))
                (hide lnm 1)
                (rolling delay)
               (hide lnm 3)
         (hide "Roll-29" 1)
        (setq n 0)
        (repeat 29
              (hide lnm 2)
              (rolling (/ delay 2))
        (hide "Roll-29" 4)(hide "Roll-29" 2)(hide "Roll-29" 1)
    Try that and see how it looks. As for the Freeze/Thaw approach. the code can be modified to accept list of layers for the _FTLayer sub.
    Thing is, the "animation" is only limited by your imagination mcclarion.
  1. Moving objects in front of — or behind — other objects: DRAWORDER
    By AutoCAD Tips Blog in forum AutoCAD RSS Feeds
    Last Post: 6th Mar 2012, 05:10 am
  2. Moving the origin for animation..help
    By bigben1103 in forum Autodesk Inventor
    Last Post: 8th Nov 2010, 10:10 pm
  3. moving objects
    By RUSSOMSTUDIO in forum AutoCAD Beginners' Area
    Last Post: 10th Jun 2010, 05:06 pm
  4. How do I make 3D objects to move in animation
    By alif in forum AutoCAD 3D Modelling & Rendering
    Last Post: 20th Feb 2009, 05:12 pm
  5. Moving objects to 0,0
    By andrewchanter in forum AutoCAD Beginners' Area
    Last Post: 23rd Sep 2008, 10:48 am
