Ssm
Diesel
Once you have got your dst file like want it with all of your custom properties that you need. How do you open that one instead of the autocad version. I tried coping and replacing the dst file but it doesn't work. Any thoughts.
Thanks
When I open a new SSM with existing dwgs it still give me the Auto-cad default. I have to open an example sheet in order to get my saved dst file...
You choose this in the SSM Options.
When you have the Sheet Set active, under the "Sheet List" tab, right-click the Sheet Set Name at the top, click Properties. From there you can choose whatever Template you want.
StyFacE,
I can't seem to figure it out. I think I am just ignorant today. When I do that I can't change the Sheet set data file.
