igones Posted May 15, 2012 Share Posted May 15, 2012 Hi, how can i find the middle point in this case? Thanks, and sorry for the dumb question. Quote Link to comment Share on other sites More sharing options...
MSasu Posted May 15, 2012 Share Posted May 15, 2012 You can use the M2P command modifier; will be asked to indicate two points and AutoCAD will calculate the middle location between them. Quote Link to comment Share on other sites More sharing options...
igones Posted May 15, 2012 Author Share Posted May 15, 2012 Hmm, nice! What can i do if i want to do a 30º line from this corner (like in the picture) to the midpoint? Quote Link to comment Share on other sites More sharing options...
Dadgad Posted May 15, 2012 Share Posted May 15, 2012 M2P is not a command by itself, as Mircea stated it is a command modifier, meaning that it is used while in the middle of another command. For instance if you were drawing a line, and had started the LINE command, when asked for the location of either the starting or end point you could enter M2P , you would then be asked to select the two defining points, after which the midpoint between them would be used as the point entry. Quote Link to comment Share on other sites More sharing options...
MSasu Posted May 15, 2012 Share Posted May 15, 2012 What can i do if i want to do a 30º line from this corner (like in the picture) to the midpoint? Activate the Ortho mode (F8) and draw a vertical line from that middle to above. Next draw another line at the desired angle - use polar relative coordinates: @100<30 Last step use TRIM or EXTEND to fix the sloped line; erase the helper entity (said vertical line). Quote Link to comment Share on other sites More sharing options...
Dadgad Posted May 15, 2012 Share Posted May 15, 2012 Hmm, nice! What can i do if i want to do a 30º line from this corner (like in the picture) to the midpoint? Use the COPY command and M2P to define the location to which you want to copy it. Quote Link to comment Share on other sites More sharing options...
igones Posted May 15, 2012 Author Share Posted May 15, 2012 Oh! Now i understood the command, thanks dadgad. So that can't be used for what i wanted, yeah? I think it's easier drawing a line in the middle and then erase it. @Edit: Thanks! Now it's everything Ok! :* Quote Link to comment Share on other sites More sharing options...
Dadgad Posted May 15, 2012 Share Posted May 15, 2012 What I would do is just turn on my MIDPOINT snap, then it gets real easy. Quote Link to comment Share on other sites More sharing options...
nestly Posted May 15, 2012 Share Posted May 15, 2012 Polar Tracking 30degrees from each side will create tracking intersection without needing to specify the midpoint or trim/erase lines afterward. Quote Link to comment Share on other sites More sharing options...
Tiger Posted May 15, 2012 Share Posted May 15, 2012 You can also while you are in your LINE-command input Quote Link to comment Share on other sites More sharing options...
MSasu Posted May 15, 2012 Share Posted May 15, 2012 command input Interesting tip – have learned something new today; thank you! Quote Link to comment Share on other sites More sharing options...
Dadgad Posted May 15, 2012 Share Posted May 15, 2012 Polar Tracking 30degrees from each side will create tracking intersection without needing to specify the midpoint or trim/erase lines afterward. [ATTACH=CONFIG]34824[/ATTACH] Right you are nestly, I had misread the OPs request, thought he was looking to construct a parallel line to the one he already had, and wasn't keen to get into polar and or parallel snaps, or offset, as he couldn't apply the M2P concept. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted May 15, 2012 Share Posted May 15, 2012 You can also while you are in your LINE-command input Tiger, me too, that is very nice, I never knew that! Quote Link to comment Share on other sites More sharing options...
