rjohnson42 Posted May 21, 2012 Share Posted May 21, 2012 I currently have my elevation view set up so that the x-coordinates correspond to the stationing along my structure and the y-coordinate corresponds to the elevations. I have a block that will insert the y-coordinate as it should. However, the x-coordinate requires some formatting so that it is shown properly (e.g. "10+00"). I have an attribute equal to a the x-coordinate divided by 100 with the precision changed to 0. So, if my point is 1016.123, the formula converts that to 10. This field is followed by a plus sign and then another field. This last field is equal to the x-coordinate minus the x-coordinate converted as before, then times 100. The purpose being that if my x-coordinate is 1016.123, I would get 16.123 and my block attribute would reflect 10+16.123. The problem is that AutoCAD retains all of the x-coordinate's precision when subtracting and I end up with a result of 0. See attached for clarity - I know this last bit is hard to understand if you can actually see what's going on. I understand that I could subtract out 1000, but when my stationing is beyond 20+00, I will only be subtracting 1000 and my result will not be correct. Do any of you have another solution? Thanks! sample.dwg Quote Link to comment Share on other sites More sharing options...
Stefan BMR Posted May 21, 2012 Share Posted May 21, 2012 This? sample1.dwg Quote Link to comment Share on other sites More sharing options...
rjohnson42 Posted May 21, 2012 Author Share Posted May 21, 2012 This?[ATTACH]34914[/ATTACH] Nice!! Is there a list of functions that can be used with fields? Thanks again, I really appreciate it! EDIT: here's a list of functions in case anyone is interested: http://www.cadforum.cz/cadforum_en/qaID.asp?tip=6381 Quote Link to comment Share on other sites More sharing options...
Stefan BMR Posted May 21, 2012 Share Posted May 21, 2012 Thank you rjohnson. A list of all available functions, besides the link you posted, can be found in Autodesk Help. All functions can be used in CAL Command, table formulas and fields. Quote Link to comment Share on other sites More sharing options...
