+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
  1. #1
    Forum Newbie
    Using
    AutoCAD 2011
    Join Date
    May 2012
    Posts
    3
    Default I can't subtract a cylinder from a wedge and a region/surface
    Dear CADTutor members,
    I have an assignment. I've done all the work until i reached the end of it which is adding 2 cylinders to a weird looking object.
    anyway, I'm trying to put the cylinder which shares a space between a wedge and a region but I'm unable to subtract it.
    Anyone can help me with this, Please?
    Best Regards,
    Sarandeeb
  2. #2
    Computer Details
    ReMark's Computer Details
    Operating System:
    Windows 7 Pro 64-bit
    Computer:
    Thinkmate
    Motherboard:
    Intel DX58SO2 LGA1366 X58
    CPU:
    RAM:
    12GB (3x4GB) PC3-106000 DDR3
    Graphics:
    nVidia Quadro 4000, 2GB GDDR5
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    ReMark's Discipline Details
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,095
    Default
    A quick check of your drawing shows that you have used a variety of entities to construct your object such as a solid, regions, lines and surfaces. For this to be done correctly I believe the object should be one complete solid.
  3. #3
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,095
    Default
    I took your object apart to show you all the surfaces (they look like a mesh), regions, three solids and a host of individual lines that went into its creation. I'm not sure who taught you this technique but it is not correct.
  4. #4
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,095
    Default
    Maybe this will help you envision the object better. It is one complete solid.
  5. #5
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,095
    Default
    A slightly different view.
    You'll need to reorient your UCS so you can create the two holes on the sloped face of your object. Extrude the two circles through your object then subtract them to create the holes. Is that clear?
    Addendum: In my haste to post the above images I totally missed the fact that the holes do not go all the way through the object. They are 10 units in depth. Sorry.
  6. #6
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,095
    Default
    Here is the object with the corrected holes.
  7. #7
    Forum Newbie
    Using
    AutoCAD 2011
    Join Date
    May 2012
    Posts
    3
    Default
    well, I don't know how to create one object like yours in order to subtract the cylinders.
    I've taken the AutoCAD courses very long time ago. This unit I'm taking, requires AutoCAD drawing but I'm unable to remember the methods I used to create complex 3d shapes. Unfortunately.
    Yours looks much smoother and I'd like to know how did you do it?
  8. #8
    Super Member
    Computer Details
    nestly's Computer Details
    Operating System:
    Windows XP Professional (32bit)
    Motherboard:
    Intel DG33FB
    CPU:
    Intel Core2 E2220 @ 2.4GHz
    RAM:
    4GB DDR2 6400
    Graphics:
    ATI Firepro 5800
    Primary Storage:
    250GB WD 7200rpm / 320GB WD 7200rpm
    Secondary Storage:
    500GB WD external USB
    Monitor:
    Samsung 26" @ 1920x1200 + LG 22" @ 1680x1050
    Using
    AutoCAD 2011
    Join Date
    Sep 2010
    Posts
    1,895
    Default
    Here's a little demo showing how to construct it as one object. I added a couple construction lines to created the "wedge" for demonstration purposes that I wouldn't have normally needed. I also used two different methods for putting the holes in the tapered face. (Cylinder > Subtract then Circle > PressPULL) Also note that Dynamic Input was enabled, which is what allowed the cylinder/circle to be drawn directly on the tapered face.
    Hope this helps, and welcome to Cadtutor.
    http://www.screencast.com/t/iygtM7hK2uC
  9. #9
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,095
    Default
    I'm going to nominate nestly for the Steven Spielberg award for Best Director of a Short Video Clip.
  10. #10
    Forum Newbie
    Using
    AutoCAD 2011
    Join Date
    May 2012
    Posts
    3
    Default
    nestly's video is AMAZING.
    LOL. I've been trying to do it part by part just like a lego toy for hours. I can't believe it.
    Thank you ReMark and nestly for your amazing support.
Similar Threads
  1. Dynamic Simulation : Cylinder in cylinder sliding joint
    By cadexplorer in forum Autodesk Inventor
    Last Post: 27th Mar 2012, 02:40 pm
  2. Wedge
    By KATIE0801 in forum AutoCAD Beginners' Area
    Last Post: 15th Sep 2010, 04:08 am
  3. 3D Wedge
    By Mk1_Oz in forum AutoCAD 3D Modelling & Rendering
    Last Post: 26th Jul 2010, 12:54 am
  4. I can subtract my cylinder from my wedge
    By ChoocH84 in forum AutoCAD Beginners' Area
    Last Post: 31st Jan 2008, 02:11 pm
  5. Wedge Command
    By Ters in forum AutoCAD 3D Modelling & Rendering
    Last Post: 12th Jun 2006, 07:47 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
