User2012 Posted June 15, 2012 Share Posted June 15, 2012 I should design a Silicone model for a Breast Cancer Survivor. My problem is the IrregularGeometric Shape of silicone. I tried "Sphere"/ "Loft" commands,but I didn't get my desired outcome! I also drew the 2D base by "Spline"; however,"Extrusion" was not a good option to make it look like a 3D silicone! Any ideas! Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 15, 2012 Share Posted June 15, 2012 Did you use a series of profiles when you tried the LOFT command? Have you considered the possibility of using a mesh object? Quote Link to comment Share on other sites More sharing options...
User2012 Posted June 17, 2012 Author Share Posted June 17, 2012 I just tried to use "Mesh Sphere" and Modify it then, and also Loft (see attachment). However, I didn't get the desired outcome. Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 17, 2012 Share Posted June 17, 2012 Yes, I could see where it would be a bit of a challenge to derive the exact shape. Having worked as a surgical technician at one time I am familiar with the implants. Quote Link to comment Share on other sites More sharing options...
User2012 Posted June 17, 2012 Author Share Posted June 17, 2012 I see! It becomes even more challenging for an actual size. Please keep me posted if you come out with any new idea. Thanx! Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 17, 2012 Share Posted June 17, 2012 I am not at my CAD computer so there will be no experimenting today unfortunately. Is this a class project? The wording of your first sentence in your starting post seems a bit strange. Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 17, 2012 Share Posted June 17, 2012 Breast implants can be round or anatomical (i.e.-teardrop, contoured or shaped). Why did you pick the one shown in your first post? Quote Link to comment Share on other sites More sharing options...
User2012 Posted June 18, 2012 Author Share Posted June 18, 2012 "Triangle Breast Form" is what I'mlooking for at this time. It looks more like the new image enclosed Quote Link to comment Share on other sites More sharing options...
JD Mather Posted June 18, 2012 Share Posted June 18, 2012 Loft will be key. But I think I would use something like Autodesk Inventor or Alias rather than Autodesk AutoCAD. Quote Link to comment Share on other sites More sharing options...
User2012 Posted June 18, 2012 Author Share Posted June 18, 2012 How about Solidworks? Quote Link to comment Share on other sites More sharing options...
JD Mather Posted June 18, 2012 Share Posted June 18, 2012 SolidWorks is equivalent to Inventor. If you have access to that - I would use it rather than AutoCAD. Quote Link to comment Share on other sites More sharing options...
lamensterms Posted June 19, 2012 Share Posted June 19, 2012 I think LOFT might be the way to go as well. You could try playing around with the MESH command - which is a pretty good way to form some organic shapes. This was created using LOFT and 3 shapes. Let me know if I can help any further. Quote Link to comment Share on other sites More sharing options...
