irishinto Posted June 27, 2012 Share Posted June 27, 2012 Hi, I am having an issue with an xref in one of my drawings. There are AEC_WALL objects in the xref file but in my drawing they show up as small triangles with an exclamation mark inside. Does anyone have an idea how to fix this? Thanks Quote Link to comment Share on other sites More sharing options...
SLW210 Posted June 27, 2012 Share Posted June 27, 2012 You need the OBJECT ENABLERS. Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted June 28, 2012 Share Posted June 28, 2012 What's happening is, you have a drawing created by AutoCAD Architectural. That package creates objects that other flavors of AutoCAD can't process correctly, so they display what are known as "proxy objects." That's what you're seeing. The Object Enablers that SLW210 pointed you toward are add-ins for AutoCAD that will display those proxy objects correctly. You can't modify them--you'd need Architectural to do that--but you can see them. Make sure you get the Object Enabler for Architectural. Quote Link to comment Share on other sites More sharing options...
