Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    Full Member
    KoTa04's Computer Details
    Windows 7
    Multi-disciplinary
    KoTa04's Discipline Details
    Multi-disciplinary
    Natural gas/hydrogen Piping HVAC
    AutoCAD 2012
    Jun 2012
    Chatham, Ontario
    32
    Default Automatic box trimming
    Hello Everyone,
    I'm quite new with autocad, and I'm trying to automate more of my work so I can finish it quicker. Any different suggestions would also be appreciated!
    Please see attached picture!
    I am currently recieving site dimensions for framing, my job is to reproduce (using isometric views) these framing dimensions in Autocad (framing is color coded white) and add metal panels (color coded blue), ultimately creating the panel dimensions to be sent to the panel manufacturer.
    Once I reproduce the framing dimensions I use a method of several offsets and construction lines to create my panels.
    My problem: each metal panel needs either 5/8" or 1/2" spacing. I am consuming a lot of time using the trim command and individually clicking out all the little squares. see picture. I like using QDIM quick dimensions to easily seperate spacing and panel dimensions, so trimming out the panels (as far as I know) is a must.
    Suggested solution: Is there a way I can tell autocad to cut out all 1/2"x1/2" or 5/8"x5/8" squares?
    As always, if you have different suggestions I am open to them.
    Thanks in advance for any replies!
    EDIT: I am using autocad 2011 LT, so I can't run script things..
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,838
    You're looking for some way to clean up all those intersecting lines?
    Full Member
    Windows 7
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2012
    Jun 2012
    Chatham, Ontario
    32
    Yes, I just want the little 1/2" or 5/8" intersecting lines cut out.
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,838
    Any reason why you did not create that pattern using an array?
  5. #5
    Full Member
    Windows 7
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2012
    Jun 2012
    Chatham, Ontario
    32
    You're looking at the reflected soffit in that picture, so at max there's typically only 20 panels, an array could be a solution then. But panels also go on the exterior of the building. In that case, there could be as few as 4 panels. An array would only take much more time.
  6. #6
    Full Member
    Windows 7
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2012
    Jun 2012
    Chatham, Ontario
    32
    In further reply to the array suggestion, here is a typical drivethru of a fast food restaurant. blue and green panels are shown here
  7. #7
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,838
    I cannot think of an easy way to trim up all those intersecting lines in LT. Requires further thought.
  8. #8
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,118
    Perhaps a small pick box, nimble zooming in and out on the scroll wheel, and precise picking
  9. #9
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,838
    I was going to suggest the judicious use of a wipeout as one possible kludge solution.
    How about a dynamic block of a panel?
  10. #10
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,590
    You can at least use the Fence option when trimming, saves you from picking every single line. Start trim, hit enter to select all, type F, enter, pick in between the line, move cursor to cross a bunch of line and pick again, repeat.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  1. Trimming
    By apowersite in forum AutoCAD Beginners' Area
    Last Post: 29th Jul 2011, 02:54 am
  2. Trimming
    By MisterJingles in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 16th Feb 2011, 05:36 pm
  3. Need some help with Trimming
    By didko in forum AutoLISP, Visual LISP & DCL
    Last Post: 25th Aug 2008, 09:22 am
  4. Need some help with Trimming
    By didko in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 22nd Aug 2008, 07:25 pm
  5. Trimming
    By jonjon in forum AutoCAD General
    Last Post: 7th Jan 2006, 07:14 pm
Tags for this Thread
