Results 1 to 1 of 1
    Senior Member
    Architectural
    AutoCAD 2018
    Nov 2010
    137
    Angry Plotting / Publishing
    AutoCAD was unintalled and reinstalled on same computer. Our IT guy thought that would help fix my crashing problems. It kinda did.... before this was done I could Publish multiable layout tabs to PDF and to the plotter/printer. We use our own setup for the PDF and potter. These have been reinstalled. te setup is the same as other computers in the office and they work fine. I can now only publish to PDF. i have to print the layout tabs one at a time, I cannot batch plot multiable tabs.
    When i go to publish the Publish Dialog box alwas comes up and is set on Pblish to...DWF format. Before it always came up..Pottler named in page setup.
    Can i set that to the Plotter named in the page setup and have it stay that way?
    When I swithc it to the plotter named in page setup it will plot to PDF but not paper?
    Any help with setting AutoCAD back up so i can Publish mulitable tabs to paper would be great.
    Thanks
    Matt
    Got it fixed.
    We had a few patches that needed to be reinstalled and now everything works just fine.
  1. Plotting / Publishing across workstations
    By mshearer in forum AutoCAD Drawing Management & Output
    Last Post: 26th Jun 2012, 12:30 pm
  2. batch plotting/publishing hundreds to pdf...
    By dlxowhd in forum AutoCAD Drawing Management & Output
    Last Post: 20th Mar 2012, 02:37 am
  3. Problems with publishing/plotting
    By VikaMann in forum AutoCAD Drawing Management & Output
    Last Post: 22nd Jan 2011, 09:42 pm
  4. Plotting / Publishing
    By Kat in forum AutoCAD General
    Last Post: 23rd Jun 2009, 07:34 pm
  5. Plotting/Publishing and the difference with lineweights
    By meleader2 in forum AutoCAD Beginners' Area
    Last Post: 4th Oct 2007, 06:04 pm
