I need a lisp to use DT command in a way that when the user press the enter no new line get started and command ends, how should I do it? absolutely no idea
never mind, got it. I should make the user press enter twice
In case you may still be interested, here is a program to do what you asked for.
(defun Text (pt hgt str)
(entmakex (list (cons 0 "TEXT")
(cons 10 pt)
(cons 11 pt)
(cons 40 hgt)
(cons 72 0) ; lower left justified
(cons 1 str)))
(defun c:dtxx (/ *ERROR* osave c txtstr txtsz)
(defun *ERROR* (msg)
(setvar "OSMODE" osave)
(setq osave (getvar "OSMODE"))
(setvar "OSMODE" 0)
(setq txtsz (getvar "TEXTSIZE"))
(setq c (getpoint "\nSelect location: "))
(initget 129)
(setq txtstr (getstring T "\nText: "))
(terpri)
(terpri)
(Text c txtsz txtstr)
(princ) )
The rotation angle is the default (zero) and the current text size is used. You could, of course, add code to get these values from the user.
