Daniel C Posted August 28, 2012 Share Posted August 28, 2012 Hi All Firstly, thank you for providing a fantastic resource for all ACAD users, of all abilities. I have a question which sadly the search function hasn't helped with. I would like to know if it is possible to turn a solid fill area into a transparent appearance. This is in a 2D drawing. Many Thanks Daniel Quote Link to comment Share on other sites More sharing options...
Dadgad Posted August 28, 2012 Share Posted August 28, 2012 Hello Daniel, welcome to the forum, that is nice of you to say. I rarely have any use for transparency, and just gave it a shot, attempting to change the transparency from BY LAYER to different numeric values, and didn't have any luck. Perhaps there IS a way, and likely somebody else may know one and be able to help you. Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 28, 2012 Share Posted August 28, 2012 Isn't there a "transparency" property for objects in Civil 3D? Making a "solid" fill "transparent". That's my chuckle for the day. Thanks. Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 28, 2012 Share Posted August 28, 2012 Dadgad: Object Transparency Property. Introduced in 2011. http://autodesk.blogs.com/between_the_lines/2010/03/autocad-2011-feature-tips-tricks-transparency.html Quote Link to comment Share on other sites More sharing options...
Daniel C Posted August 28, 2012 Author Share Posted August 28, 2012 Yeah, what my objective is would be to fill an area with a transparent colour, not a solid colour, hopefully that is a bit more understandable. Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 28, 2012 Share Posted August 28, 2012 Did you see the link I posted for Dadgad? Not sure if it applies to your situation. Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 28, 2012 Share Posted August 28, 2012 Have you seen this by Dana Probert ( BIM on the Rocks) Civil 3D 2011: Using AutoCAD 2011 Layer Transparency for Civil 3D Objects One of the new features for AutoCAD 2011 is the ability to make a layer transparent. Since Civil 3D 2011 is built on AutoCAD 2011, you can take advantage of this new tool. Think of all of that hatching we’ve done over the years- how awesome to make it transparent! It should work for solid fills yes? Quote Link to comment Share on other sites More sharing options...
Daniel C Posted August 28, 2012 Author Share Posted August 28, 2012 Thank you very much for the link ReMark. I appreciate you taking the time, and yes it was what I have been looking for. Many Thanks. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted August 28, 2012 Share Posted August 28, 2012 Dadgad: Object Transparency Property. Introduced in 2011. http://autodesk.blogs.com/between_the_lines/2010/03/autocad-2011-feature-tips-tricks-transparency.html Thanks ReMark, I've seen it around, just not had any real use for it, although I am a big fan of the X-RAY visualstyle. When I tried this a few minutes ago I changed the transparency of a solid from BY LAYER to numbers ranging up to 90, but couldn't see any change. Is it meant to display too, not just for printing, right? I think i have turned it off globally in my SYSVDLG. Now I got it working, had to change my HPTRANSPARENCY variable setting. Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 28, 2012 Share Posted August 28, 2012 A twofer! You're both entirely welcomed. Quote Link to comment Share on other sites More sharing options...
