MisterJingles Posted September 4, 2012 Share Posted September 4, 2012 Hi all Something strange is happening with my ACAD at the moment. If I click an object and then push ESC to remove focus from it, ACAD does not register the ESC command. So I cant undo the focus on that object. I have to close and reboot ACAD to solve the problem. Its happened 4 or 5 times now over the past 2 days and I need to resolve it. I am running the latest Autodesk update. Any ideas? Rob Quote Link to comment Share on other sites More sharing options...
Dadgad Posted September 4, 2012 Share Posted September 4, 2012 Might the user PROFILE which is current be the wrong one? PICKFIRST set to 0, maybe? DIMSPACE......no, that last one is a joke. Been there not done that! Quote Link to comment Share on other sites More sharing options...
Tiger Posted September 4, 2012 Share Posted September 4, 2012 Is the object still selected or is it just that the hightlight (dashing and/or thickening) is still on the object? It happens to me sometimes that the hightlight is still there even if I hit Escape. Usually it happens when I am using a more or less poorly written lisp/script... Can you use the ESC-button to abort a command? If so, can you after you have hightlighed an object, start a command (such as UNDO) and the hit ESC to cancel it all? Quote Link to comment Share on other sites More sharing options...
fuccaro Posted September 4, 2012 Share Posted September 4, 2012 Try REGEN or REDRAW. Quote Link to comment Share on other sites More sharing options...
MisterJingles Posted September 4, 2012 Author Share Posted September 4, 2012 It only started happening 2 days ago and happens randomly (or so it seems) Tiger the object shows the grips, ESC, REGEN, don't work. Although I do get that other form of selection (often), but I dont work with LISPs. fuccaro I will attempt a REDRAW when next it happens. Dadgad I will also check your suggestions when next it happens. Quote Link to comment Share on other sites More sharing options...
