nrschmid Posted September 19, 2012 Share Posted September 19, 2012 Instead of a window popping up with the hatch settings, I just get the following in the command prompt: Pick internal point or [select objects/settings}: Any idea what might be causing this? Thanks- Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 19, 2012 Share Posted September 19, 2012 It seems you have lost your dialog box. Is this also true if you run the Plot command for instance? Just checking something. Quote Link to comment Share on other sites More sharing options...
nrschmid Posted September 19, 2012 Author Share Posted September 19, 2012 Plot dialog box/window works. So far it looks like it is just the HATCH and BHATCH commands. Quote Link to comment Share on other sites More sharing options...
rkent Posted September 19, 2012 Share Posted September 19, 2012 You have to type T (setTings) now, or pick setTings from the command line or from dynamic input. Quote Link to comment Share on other sites More sharing options...
nrschmid Posted September 19, 2012 Author Share Posted September 19, 2012 I did that which worked, but it seems like a several more keystrokes than just "H". Quote Link to comment Share on other sites More sharing options...
rkent Posted September 19, 2012 Share Posted September 19, 2012 The new function makes sense if you use the Ribbon, it not either type the extra key or set it up in a button to do that for you. Quote Link to comment Share on other sites More sharing options...
ringas Posted September 19, 2012 Share Posted September 19, 2012 Or just set HPDLGMODE to 1 Quote Link to comment Share on other sites More sharing options...
