knattagh Posted September 27, 2012 Share Posted September 27, 2012 Can I make an object like the one I drew and then adjust the lengths of its various faces to whatever values I like? If so can you point me in the right direction please? Thanks Quote Link to comment Share on other sites More sharing options...
nod684 Posted September 27, 2012 Share Posted September 27, 2012 (edited) Can I make an object like the one I drew and then adjust the lengths of its various faces to whatever values I like? If so can you point me in the right direction please? Thanks[ATTACH=CONFIG]37484[/ATTACH] Have you tried Presspull command? Edited September 27, 2012 by nod684 Quote Link to comment Share on other sites More sharing options...
iainlines Posted September 27, 2012 Share Posted September 27, 2012 Presspull or if you want to go old school Extrude Faces Quote Link to comment Share on other sites More sharing options...
knattagh Posted September 27, 2012 Author Share Posted September 27, 2012 Yes I tried to push pull but I want to be able to know how long my faces are so I can push or pull the face exactly the distance I want. Thanks Quote Link to comment Share on other sites More sharing options...
iainlines Posted September 27, 2012 Share Posted September 27, 2012 Take a dimension? If you drew it, don't you know how long the faces are? Sorry, just trying to understand Quote Link to comment Share on other sites More sharing options...
Dadgad Posted September 27, 2012 Share Posted September 27, 2012 Welcome to the forum. Explore all of the controls which are circled in RED on the ribbon in the image, they could all come into play, depending on how you chose to do it. You may want to turn on your DYNAMIC INPUT too. PRESSPULL is great for fast and loose, pushing holes through pieces and such, but lacks the direct dimensional input that you are talking about. Quote Link to comment Share on other sites More sharing options...
iainlines Posted September 27, 2012 Share Posted September 27, 2012 Good advice ^^^ Also, with Dadgad you always get a rather helpful image! :-) Quote Link to comment Share on other sites More sharing options...
Dadgad Posted September 27, 2012 Share Posted September 27, 2012 Yes I tried to push pull but I want to be able to know how long my faces are so I can push or pull the face exactly the distance I want. Thanks Command: _solidedit Solids editing automatic checking: SOLIDCHECK=1 Enter a solids editing option [Face/Edge/Body/Undo/eXit] : _face Enter a face editing option [Extrude/Move/Rotate/Offset/Taper/Delete/Copy/coLor/mAterial/Undo/eXit] : _move Select faces or [undo/Remove]: 1 face found. Select faces or [undo/Remove/ALL]: Specify a base point or displacement: Specify a second point of displacement: 35 Solid validation started. Quote Link to comment Share on other sites More sharing options...
nod684 Posted September 27, 2012 Share Posted September 27, 2012 Yes I tried to push pull but I want to be able to know how long my faces are so I can push or pull the face exactly the distance I want. Thanks issue Presspull command pick a face then move your move, then enter the required press or pull distance Quote Link to comment Share on other sites More sharing options...
JD Mather Posted September 27, 2012 Share Posted September 27, 2012 Ctrl select face, then.... Sounds like what you need first is Measure or ID or Viewbase and dimensions. Quote Link to comment Share on other sites More sharing options...
