KarolR Posted September 29, 2012 Share Posted September 29, 2012 Sketch 12 is fully defined. i cannot add coincident endpoints. I try to cut extrude it, but it says the contour isn't closed. drum 2.zip Quote Link to comment Share on other sites More sharing options...
JD Mather Posted October 1, 2012 Share Posted October 1, 2012 Do not use zero (0) length dimensions. Delete the dimension. Drag the sketch a bit from it's current position. Hit Esc. Hold the Ctrl key and select endpoint of sketch and endpoint of geometry and add coincident relation. Repeat on other end of line. Quote Link to comment Share on other sites More sharing options...
