Results 1 to 2 of 2
Thread: PDF Clip
    Junior Member
    AutoCAD 2009
    Jan 2009
    14
    Default PDF Clip
    Hello,
    I am trying to use the PDFCLIP command to clip an underlayed PDF. The problem is, I am trying to clip multiple sections from this PDF and am struggling to do so.
    I select the underlay, select Create Clipping Boundary, select the polyline I want to use and invert it and it clips out the area. When I try to do this again, it won't let me keep the existing boundary and create another one. It seems like I can only crop one area at a time?
    Hopefully this makes sense and any help would be appreciated!
    Senior Member Bogbadbob658's Avatar
    Bogbadbob658's Computer Details
    Windows 7
    Asus P8P67 LE
    Intel 2nd Generation Coreā„¢ i5-2500
    8GB 1333MHz Dual Channel DDR3 SDRAM
    512MB Nvidia GeForce Quadro FX 580
    1TB Samsung F3 SATA 7200rpm 32MB Cache
    24" Iiyama LCD Monitor - Full HD 1920x1080
    Architecture 2013
    Aug 2007
    Gloucester UK
    327
    I belive you are correct in that you can only clip a pdf once. What you need to do is draw a polyline that goes around both areas in one continous go. Imagine drawing the outline of a dumb bell without moving the pen off the paper. Note however the lines mustn't touch, you have to keep a very small gap. Not perfect but it's the only way I can think of doing it.
    The alternative is to use a wipeout to block out what you don't want.
  1. OUTLINE and CLIP in AC 12 Lt
    By netman in forum AutoCAD General
    Last Post: 19th Aug 2012, 12:59 am
  2. OLE Clip
    By NKG in forum AutoCAD Drawing Management & Output
    Last Post: 9th Jul 2008, 05:48 am
  3. Clip a dwg. within boundaries
    By studiorat in forum AutoCAD General
    Last Post: 1st Feb 2008, 06:45 pm
  4. X-Clip Problem
    By Rosa in forum AutoCAD Drawing Management & Output
    Last Post: 4th Jan 2008, 10:39 pm
  5. Clip art...
    By Alan Cullen in forum AutoCAD Drawing Management & Output
    Last Post: 13th Aug 2007, 04:03 pm
