IronHorse Posted October 11, 2012 Share Posted October 11, 2012 I work in company wich produces bricks in different qualitys. I need to generate different colours for different qualitys. Plain colours like yellow (255.255.0) no problem to create. But if I need the same colour with f.ex speckles how do I accomplish that? Have tried a long time but whatever pattern I choose do not appear on modell or drawing. I do not want to use any image or bump map. Just simple colur with pattern. Quote Link to comment Share on other sites More sharing options...
Bishop Posted October 11, 2012 Share Posted October 11, 2012 Sorry, you'll need an image map and / or bump map. They're pretty quick and simple to create, you just need to spend some time with Photoshop or similar. Quote Link to comment Share on other sites More sharing options...
IronHorse Posted October 12, 2012 Author Share Posted October 12, 2012 This is not the same question we just try to preserve the apperance With the material, it jumps back to general when we finished. Quote Link to comment Share on other sites More sharing options...
Lazer Posted October 12, 2012 Share Posted October 12, 2012 I can only guess the jumping back to the original colour is because you are in an assembly. If select the colour to the part (.itp) then then in an assembly (.iam) select colour as part. This can be a little confusing at first but give it a go. Quote Link to comment Share on other sites More sharing options...
