2217 Posted November 5, 2012 Share Posted November 5, 2012 (edited) I'm using 3D Max Design. I am unable to move an object on the Z axis of the gizmo. When I attempt to do so, a yellow line follows the path of my drag. I can move an object up and down only if I drag by all 3 axis. Edited November 5, 2012 by 2217 Quote Link to comment Share on other sites More sharing options...
Dadgad Posted November 5, 2012 Share Posted November 5, 2012 Welcome to CADTutor. Pardon my asking which of the 3D Gizmos you are trying to use for the 3D MOVE? I suggest that you set an ISOMETRIC perspective, if you have not already, and try again. You might want to turn on ORTHO or POLAR, and your DYNAMIC UCS, in which case you won't even need the gizmo in question. Once again use an ISOMETRIC perspective. Quote Link to comment Share on other sites More sharing options...
2217 Posted November 5, 2012 Author Share Posted November 5, 2012 Welcome to CADTutor. Pardon my asking which of the 3D Gizmos you are trying to use for the 3D MOVE? I suggest that you set an ISOMETRIC perspective, if you have not already, and try again. You might want to turn on ORTHO or POLAR, and your DYNAMIC UCS, in which case you won't even need the gizmo in question. Once again use an ISOMETRIC perspective. Thanks! I'm sorry. I'm using 3d Max Design. -forgot to note that Looks like this question would be better suited in the 3D Forum. oops Quote Link to comment Share on other sites More sharing options...
Dadgad Posted November 5, 2012 Share Posted November 5, 2012 I noticed you referenced using 3Ds Max Design in your profile, but I saw you had posted in the Autocad forum, so took a shot. You definitely want to post it wherever the people who can help you the most, are most likely to see it, in a timely fashion. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted November 5, 2012 Share Posted November 5, 2012 I have relocated this thread to the 3DS max forum. Quote Link to comment Share on other sites More sharing options...
