Arty Posted November 9, 2012 Share Posted November 9, 2012 Hi, I'm wondering if there is a way to "copy" info(part of drawin) from one drawing to another and make the copy land on the exact same spot in the new drawing? /Arty Quote Link to comment Share on other sites More sharing options...
Dadgad Posted November 9, 2012 Share Posted November 9, 2012 Easily done, PASTE TO ORIGINAL COORDINATES. The commandline version is PASTEORIG, or you can find it with the CLIPBOARD commands in your right click shortcut menu, or on the PASTE panel on the ribbon. Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted November 9, 2012 Share Posted November 9, 2012 Another method is to xref the drawing into the correct location and use NCOPY. For some reason that command doesn't preserve blocks, that is, you can only copy basic objects. When you select, for instance, a line belonging to a block, you get the line by itself, not the whole block. If you have a lot of stuff to copy, consider binding the xref with the Insert option. You can edit the resulting block to remove what you don't want and then explode it. If you use Dadgad's method, and you're not sure about the scale or rotation, use the Paste as Block option. You can adjust the block as a whole and then explode it. Quote Link to comment Share on other sites More sharing options...
DashaB Posted November 9, 2012 Share Posted November 9, 2012 I've always used COPYBASE and the coordinates 0,0,0. the fast way to do that is Ctrl+Shift+C Quote Link to comment Share on other sites More sharing options...
