suryatry26 Posted November 29, 2012 Share Posted November 29, 2012 How to remove this Pdf layers (Delete)?Using Pdf editer Acrobat/9.0 version? Quote Link to comment Share on other sites More sharing options...
f700es Posted November 29, 2012 Share Posted November 29, 2012 I have Acrobat Pro X and I tried to see if I could in it and I can't see any where that would allow me to delete a layer. I also tried to open the PDF in Illustrator CS5.1 but the layer information did not transfer over from the PDF in Illustrator. I also tried in Corel Draw X6 and it did not show the layers either. Sorry looks like you are stuck with it. Quote Link to comment Share on other sites More sharing options...
Organic Posted November 29, 2012 Share Posted November 29, 2012 In Acrobat X, in the layers pane there is a little drop down button at the top, and in there is the 'Merge layers' option where you can easily merge all the layers to layer 0 say and then layers are effectively gone (drawing remains unchanged though). Not sure if Acrobat 9 has something similar. Quote Link to comment Share on other sites More sharing options...
f700es Posted November 29, 2012 Share Posted November 29, 2012 Yeah I saw the merge layer command. If there is info on this layer wouldn't it get merged onto the other layer? Quote Link to comment Share on other sites More sharing options...
Organic Posted November 30, 2012 Share Posted November 30, 2012 Yeah I saw the merge layer command. If there is info on this layer wouldn't it get merged onto the other layer? Yes. Which is what we want right? Quote Link to comment Share on other sites More sharing options...
