Hi all,
I have these lisp from Alan J Thompson that includes a plot reactor from LeeMac that functions brilliantly.
;Based on PageSetups from Alan J. Thompson
(defun c:A3 ()
(command "_.-layer" "_LW" "0.13" "CCC_LAYOUT_Dimensions" "")
(PlotReactorOFF)
 (if (findfile "T:/Drawing Tools/Templates/CCC2009.dwt")
     (command "_.psetupin" (findfile "T:/Drawing Tools/Templates/CCC2009.dwt") "A3")
     (while (wcmatch (getvar "cmdnames") "*PSETUPIN*")
       (command "_yes")
     ) ;_ while
     T
   ) ;_ progn
 ) ;_ if
(command "-plot" "n" "" "A3" "" "n" "y" "n")
(command "_-purge" "a" "*" "N")
(setq CCC_Sheet "A3")
(command "updatefield" "all" "")
(command "regenall")
(command "_zoom" "e")
 (initdia)
 (command "._plot")
(PlotReactorON)
;(princ)
(defun PlotReactorON nil
 (vl-load-com)
 ;; © Lee Mac 2010
 (  (lambda ( data foo / react )
      (if (setq react
            (vl-some
              (function
                (lambda ( reactor )
                  (if (eq data (vlr-data reactor)) reactor)
              (cdar
                (vlr-reactors :vlr-command-reactor)
        (if (not (vlr-added-p react))
          (vlr-add react)
        (setq react
          (vlr-command-reactor data
            (list
              (cons :vlr-commandwillstart foo)
      (if (vlr-added-p react)
        (princ "\n** Reactor Activated **")
        (princ "\n** Reactor Failed to Activate **")
      react
   "Plot-Reactor"
   'Plot-Callback
(defun PlotReactorOFF nil
 (vl-load-com)
 ;; © Lee Mac 2010
      (if (setq react
            (vl-some
              (function
                (lambda ( reactor )
              (cdar
          (vlr-remove react)
      (if (or (not react) (not (vlr-added-p react)))
        (princ "\n** Reactor Deactivated **")
        (princ "\n** Reactor Failed to Deactivate **")
      react
   "Plot-Reactor"
   'Plot-Callback
(defun Plot-Callback ( reactor arguments )
 (vl-load-com)
 (if (eq (strcase (car arguments)) "PLOT")
   (LM:Popup "Warning" 64 "Gotcha!!!   Please use the NNRDO Plot tools when plotting standard layouts!!")
(defun LM:Popup ( title flags msg / WSHShell result )
 ;; © Lee Mac 2010
 (setq WSHShell (vlax-create-object "WScript.Shell"))
 (setq result   (vlax-invoke WSHShell 'Popup msg 0 title flags))
 (vlax-release-object WSHShell)
 result
However, I would like to modify it to do the following. I have the "Use paper space units for scaling" box checked on in our standard template which is what I need for our service drawings. However this makes lining drawings look wrong when printed because dashes for road lining appear too short.
I would like to be able to test to see if the attribute TAGD2 within the block "CCC_Drawing_Types" is set to LS and then check if the "Use paper space units for scaling" is checked. If so invoke a dialog box telling the user to uncheck it and the launch the LT dialog box and when they click ok to resume with the plot window.
I know it sounds like I have my ideas sorted out but I have no idea where to begin. I found one of LeeMac's lisp to extract an attibute from a block but I don't know how to incorporate it.
(defun c:sk (/ dxf ent)
 (defun dxf (code ent) (cdr (assoc code (entget ent))))
 (if (and (setq ent (car (entsel "\nSelect an Attributed Block: ")))
          (eq "INSERT" (dxf 0 ent))
          (= 1 (dxf 66 ent)))
   (while (not (eq "SEQEND" (dxf 0 (setq ent (entnext ent)))))
     (princ (strcat "\n\nAtt_Tag:" (dxf 2 ent) "\nAtt_Value: " (dxf 1 ent)))))
 (princ))
I would appreciate any help on this.
