Results 1 to 8 of 8
Thread: Curved Line
    Forum Newbie
    AutoCAD 2013
    Oct 2012
    3
    Default Curved Line
    He all
    Im very new to autocad and i am using 2013 student there is two things i need help with.
    1) I have drawen a curved line for a Directional Drill Shot and need to create a points on it every 2 metres to give a Cord postion,
    2)I need to beable to transfer these points into a excel spread sheet.
    Many thanks
    Alex
    Senior Member
    aaryan's Computer Details
    Windows 7 x32 bit
    Map 3D 2014
    May 2011
    autocad
    153
    Hi,
    You can use "measure" command to draw points on line at equal interval.
    Command: measure
    Select object to measure:
    Specify length of segment or [Block]: 2
    Secondly, search this forum you will find some of the autolisp code to export points from autocad to excel or txt.
    I hope this is what u need.
    Regards
    Aaryan
    Forum Newbie
    AutoCAD 2013
    Oct 2012
    3
    Thanks you for your help you have helped me with my first problem many thanks but i have just had a look about and ended up at a website but im not sure what program i would need to use you option would be great
    http://www.lee-mac.com/programs.html
    Many thanks
    Alex
    Managed to find the program i want now and managed to get some points into text files but going back to my 1st question.
    So i have create points what look like crosshairs but as i have over 100 with every drill shot it will take forever to single select each one to export is there away to select them all quickly without selecting everything else on the drawing
    Many thanks
    alex
    Senior Member
    Windows 7 x32 bit
    Map 3D 2014
    May 2011
    autocad
    153
    Try this code. This should help you out.
    Code:
    (defun C:test (/ ss fil opn ctr prop pnt X Y Z)
      (setq ss (ssget '((0 . "POINT"))))
      (setq fil (getfiled "Save File as" "*.*" "csv" 1)
    	opn (open fil "w"))
      (setq ctr 0)
      (repeat (sslength ss)
        (setq prop (entget (ssname ss ctr))
    	  pnt (cdr (assoc 10 prop))
    	  X (rtos (car pnt))
    	  Y (rtos (cadr pnt))
    	  Z (rtos (caddr pnt)))
        (write-line (strcat X "," Y "," Z) opn)
        (setq ctr (1+ ctr)))
      (close opn)
    Copy and paste this code to notepad file and save it as "Test.lsp". Dont forget to put "*.lsp" extension.
    Now come to autocad and type "appload" ont the command line, navigate to "Test.lsp" wherever you have saved, select the file and press load and then close the dialog box.
    Type "test" at the command line and select objects(points) and press enter and save the file. open that file (which is in csv format) in excel.
    Hope it helps
  5. #5
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,358
    You can also use the Data Extraction Wizard native to AutoCAD.
  6. #6
    Forum Newbie
    AutoCAD 2013
    Oct 2012
    3
    Many thanks for all your help and i will most probly be back soon asking for me help
    Alex
  7. #7
    Senior Member
    Windows 7 x32 bit
    Map 3D 2014
    May 2011
    autocad
    153
    You are welcome Alex
    Regards
  8. #8
    Senior Member
    Windows 7 x32 bit
    Map 3D 2014
    May 2011
    autocad
    153
    Wow!
    Thank You Sir!!
  1. How to draw this curved line?
    By LTAZ in forum AutoCAD Beginners' Area
    Last Post: 28th Dec 2012, 01:49 pm
  2. Replies: 9
    Last Post: 28th Jun 2012, 05:01 am
  3. Sectioning along a curved line
    By pvd in forum Autodesk Inventor
    Last Post: 4th Dec 2008, 08:52 pm
  4. Offsetting along a curved line
    By MarkCalvert in forum AutoCAD General
    Last Post: 1st Nov 2007, 12:21 pm
  5. Create text along a curved line
    By lekkaut in forum AutoCAD General
    Last Post: 5th Mar 2004, 07:23 pm
