Siberian Posted December 26, 2012 Share Posted December 26, 2012 For some reason when I use isometric view or some other form of 3D view, the mouse pointer doesn't conform with the crosshair. If I hover the crosshair over an object, another object about 7 cm above it on my screen highlights! Still, if I try select an object, it's the one beneath the crosshairs that gets selected. Using the wheel to zoom however, follows this other illusionary point. Anyone got a solution for this wierd behavior? Quote Link to comment Share on other sites More sharing options...
Dadgad Posted December 27, 2012 Share Posted December 27, 2012 You might want to try this, in your OPTIONS ... Quote Link to comment Share on other sites More sharing options...
waz2010 Posted June 3, 2013 Share Posted June 3, 2013 You might want to try this, in your OPTIONS ... I have the same issue....anyone know if there is a solution. The above didnt work for me. Is this an autocad bug?? thx Quote Link to comment Share on other sites More sharing options...
Dadgad Posted June 3, 2013 Share Posted June 3, 2013 Welcome to CADTutor! This isn't a bug. I suspect that if you snap to one of these objects, then switch to your TOP view you will find that your OSNAP was tracking the object in question, but with an altered Z state. Look in OPTIONS on your Drafting tab, and you will likely discover that one or both of the settings highlighted in yellow in the attachment is/are mandating this behavior. Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 3, 2013 Share Posted June 3, 2013 I have experienced altered "Z" states in the past. It sually happens when I power down my nuclear sub-system for the evening. LoL Quote Link to comment Share on other sites More sharing options...
