Hi guys,
i have a polyline of 10,000m, and i want to plot one attribute block on that on the interval of every 1000m. But the block should be plot in incremental number
for example,
DC-1 on 1000m
DC-2 on 2000m
DC-3 on 3000m
the interval may changes to 500m or 2000m but it should follow the proper increment.
I need a lisp t solve this problem....plz help
find out attached drawing for the referance
Test_DC.dwg
  • Replies 30
  • Tharwat
    14
  • rayboy
    8
  • gS7
    5
  • satishrajdev
    3
Here ... try this code:
(defun c:inat
      (/ cme pli plis inc ptli stpt lapt dis ang noi icl icn cnt)
 (setq cme (getvar 'cmdecho)
osm (getvar 'osmode)
 (setvar 'cmdecho 0)
 (setvar 'osmode 0)
 (setq	pli  (car (entsel))
plis (entget pli)
inc  (getreal "\nSet increment value: ")
ptli (list)
 (foreach ip plis
   (if	(= (car ip) 10)
     (setq ptli
     (append ptli
	     (list
	       (cdr ip)
 (setq	stpt (car ptli)
lapt (last ptli)
dis  (distance stpt lapt)
ang  (angle stpt lapt)
noi  (fix (/ dis inc))
icl  (list)
icn  1
 (repeat (1- noi)
   (setq icl
   (append icl
	   (list
	     (polar stpt ang (* inc icn))
   (setq icn (1+ icn))
 (setq cnt 1)
 (foreach blip	icl
   (command "-insert"
     "DC"
     blip
     (strcat "DC-"
	     (if (> cnt 9)
	       (itoa cnt)
	       (strcat "0" (itoa cnt))
   (setq cnt (1+ cnt))
 (setvar 'cmdecho cme)
 (setvar 'osmode osm)
It only works on single segment polylines!
Edited by CAD89
Thankx CAD89 for ur efforts
This is good for single segment polyline, but i am normally works with multi segment polylines.........
Hey Try This
Note: Before Run This Program Please INSERT Block "DC" on your Drawing
(defun c:Test (/ cmh ss i cnt n l blockname)
   (vl-load-com)
   (setq cmh(getvar 'cmdecho))
  [color="blue"] (setq att (getvar 'attreq))[/color]
(setvar 'cmdecho 0)
       [color="blue"](setvar 'attreq 1)[/color]
   (if (setq ss(car (entsel "\nPick Polyline:")))
	    (setq i (getreal "\nIncrement Distance:"))
		(setq n i)
		(setq cnt 1)
		(setq l (vlax-curve-getdistatparam ss (vlax-curve-getendparam ss)))
		(repeat (fix(/ l i))
		    (setq npt(vlax-curve-getpointatdist ss i))
               (if (> cnt 9)
			    (setq Blockname (strcat "DC-"(rtos cnt 2 0)))
				(setq Blockname (strcat "DC-0"(rtos cnt 2 0)))
			(command "_INSERT"[color="blue"] "DC"[/color] npt "" "" blockname)
            (setq cnt(1+ cnt))
			(setq i(+ n i))
(setvar 'cmdecho cmh)
       [color="blue"](setvar 'attreq att)[/color]
);defun
Edited by gS7
Thankx Ganesh...........This is was i was looking for
Solved my problem
@Ganesh .
Be careful , the increment would be from right to left if the polyline starts from right to left :thumbsup:
Suppose that we're talking about a polyline that its start point is on the right side and the end is on the left side , or on the contrary .
You can check the X coordinates of the two points which one of them is bigger or less than the other one , depending on that you can
insert your Block definition accordingly .
Tharwat i didn not understand ur point ..i requesting you to please rivise my codes thank you
No worries , I have wrote a routine at the office today in regard to this issue so tomorrow I will post the code because now I am at home. :D
Try this ...
(defun c:Test (/ *error* IsAttributed Spread_The_Block s d l blk at)
 (vl-load-com)
 ;; Tharwat 15. 01. 2013 ;
 (defun *error* (x)
   (if at
     (setvar 'attdia at)
   (princ "\n*Cancel*")
 (or Doc (setq Doc (vla-get-ActiveDocument (vlax-get-acad-object))))
 (defun IsAttributed (Doc name / yes)
   (vlax-for o (vla-item (vla-get-blocks Doc) name)
     (if (eq "AcDbAttributeDefinition" (vla-get-objectname o))
       (setq yes t)
   yes
 (defun Spread_The_Block (s l d rm blk / sg i mrk)
   (if rm
     (setq sg  rm
           i   (* d (fix (/ l d)))
           mrk '-
     (setq sg  d
           i   d
           mrk '+
   (repeat (fix (/ l d))
     (vl-cmdf "_.-insert"
              blk
              "_non"
              (vlax-curve-getpointatdist s sg)
              "1."
              "1.0"
              "0."
              (strcat "DC-" (rtos i 2 0))
     (setq sg (+ sg d)
           i  (apply mrk (list i d))
 (setq blk "DC")  ;; Specify Attibuted block name here with one attributes
 (if (and (if (not (tblsearch "BLOCK" blk))
            (progn (princ "\n Block name is not found in Drawing !!") nil)
            t
          (if (not (IsAttributed Doc blk))
            (progn (princ "\n Block name is not Attributed Block !!") nil)
            t
          (setq d (getreal "\n Increment Distance:"))
          (setq s (car (entsel "\n Select Polyline:")))
   (progn (setq at (getvar 'attdia))
          (setvar 'attdia 0)
          (setq l (vlax-curve-getdistatparam s (vlax-curve-getendparam s)))
          (if (> (car (vlax-curve-getstartpoint s)) (car (vlax-curve-getendpoint s)))
            (Spread_The_Block s l d (rem l d) blk)
            (Spread_The_Block s l d nil blk)
          (setvar 'attdia at)
 (princ "\nWritten by Tharwat Al Shoufi")
Tharwat I am impressed thank you
I am very happy that you like it . :thumbsup:
  • 2 years later...
Tharwat,
I've just discovered your lisp routine for placing attributed blocks along a polyline. It's very good and almost perfect for my requirements and I have a question for you.
Would it be difficult to make the block insert so that it is perpendicular to the polyline (even around a curve) instead of vertical as it is currently?
I'm trying to learn lisp so if you could point me in the right direction I'm willing to give it a try!
regards
John
Welcome to CADTutor rayboy.
Can you please give an example showing your desire goal of the program regardless of the fore-said program in this thread ?
Upload a sample drawing if you can .
Or here is the way of how to play with the angle .
NOTE: Don't forget to localize the variable 'p' in the program.
              blk
              "_non"
              (setq p (vlax-curve-getpointatdist s sg))
              "1."
              "1.0"
              (/ (* (angle '(0. 0. 0.)
                           (vlax-curve-getfirstderiv
                             s
                             (vlax-curve-getparamatpoint s p)
                    180.0
                 pi
Thank you Tharwat, it's nice to be here.
I've attached a simple drawing showing an example.
The top example is what the lisp produces. The bottom example is what I would like.
The blocks should be perpendicular to the polyline (like teeth on a gear wheel).
It would be nice as well if it could insert a block at the start point (0.0) and number them 0.0, 0.5, 1.0, 1.5 etc.
kp-test.dwg
This is not perfect but it does the trick very well and now you can select more objects than just a polyline.
Try it.
(defun c:Test (/ *error* do isattributed spread_the_block s d l blk vals
              p
 ;; Tharwat 26. 08. 2015 ;
 (defun *error* (x)
   (if vals
     (mapcar 'setvar '(attdia dimzin) vals)
 (defun isattributed (doc name / yes)
   (vlax-for o (vla-item (vla-get-blocks doc) name)
       (setq yes t)
   yes
 (defun spread_the_block (s l d blk / sg i mrk)
   (setq sg  d
         i   d
         mrk '+
            blk
            "_non"
            (setq p (vlax-curve-getstartpoint s))
            "1."
            "1.0"
                           s
                  180.0
               pi
            (strcat "DC-" "0.0")
              blk
              "_non"
              "1."
              "1.0"
                             s
                    180.0
                 pi
              (strcat "DC-" (rtos i 2 1))
     (setq i  (apply mrk (list i d))
           sg (+ sg d)
 (setq blk      "kptag1"
       do       (vla-get-activedocument (vlax-get-acad-object))
       *incval* (if *incval*
                  *incval*
                  0.5
 (if
   (and
       (progn (princ "\nBlock name is not found in Drawing !!")
              nil
       t
     (if (not (isattributed do blk))
       (progn (princ "\nBlock name is not Attributed Block !!")
              nil
       t
     (progn (initget 6)
            (setq
              *incval* (cond ((getdist (strcat "\n Increment Distance <"
                                               (rtos *incval* 2 2)
                             (t *incval*)
     (setq s (car (entsel "\nPick on [Polyline,Line,Arc,Spline]:")))
     (wcmatch (cdr (assoc 0 (entget s)))
              "LWPOLYLINE,LINE,ARC,SPLINE"
    (progn (setq vlas (mapcar 'getvar '(attdia cmdecho dimzin)))
           (mapcar 'setvar '(attdia cmdecho dimzin) '(0 0 0))
           (vla-startundomark do)
           (spread_the_block s l *incval* blk)
           (vla-endundomark do)
 (*error* nil)
)(vl-load-com)
Edited by Tharwat
Thanks Tharwat, that's getting very close.
I can't get the text to start from 0 (it starts at 0.5) then it doesn't show the decimal place for the whole numbers (it shows 1 instead of 1.0). I've adjusted the RTOS value but it doesn't display the 1.0 format.
