Currently our company standard layers can be inserted as a block. This works great allowing everyone to see whats what. I made two .dws files with the layer translator that switch all existing layers to new and all new to existing. The only issues is once the layers are translated, I loose either the New layers or the Existing layers. If I reinsert our company standard layers block, it isn't redefined and the new or existing layers still do not exist. I basically need to redefine the block as it is reinserted into my drawing.
(defun c:SAA ()
(setq new (getpoint "\n SPECIFY INSERTION POINT:"))
(if (findfile "J:/SAA CADD Standards/LAYERS/LAYERS.dwg")
(command "_insert" "J:/SAA CADD Standards/LAYERS/LAYERS.DWG" new "1" "" "0" "")
); end if
); end function
snip.. snip
(if (tblsearch "block" blkname)
     (command "._-insert" (strcat blkname [color="blue"][b]"="[/b][/color]) (command))
     (princ (strcat "\nBlock " (strcase blkname) " redefined."))))
