MSasu Posted February 2, 2013 Share Posted February 2, 2013 Please try to replace those lines: (command "text" (list (+(atof xstr)(/ (atof httt) 2.0)) (cadr gptx)) httt "90" (strcat xstr)) (command "text" (list (+(atof xstr)(/ (atof httt) 2.0)) (cadr gpty)) httt "90" (strcat ystr)) with those: (entmakex (list (cons 0 "MTEXT") (cons 100 "AcDbEntity") (cons 100 "AcDbMText") (cons 10 (list (+ (nth 0 ITEM) (/ (atof httt) 3.0)) (cadr gptx))) (cons 50 (* 0.5 pi)) (cons 1 xstr))) (entmakex (list (cons 0 "MTEXT") (cons 100 "AcDbEntity") (cons 100 "AcDbMText") (cons 50 (* 0.5 pi)) (cons 10 (list (+ (nth 0 ITEM) (/ (atof httt) 3.0)) (cadr gpty))) (cons 1 ystr))) and check if this is the result you were looking for. Quote Link to comment Share on other sites More sharing options...
mfahadrazzaq Posted February 12, 2013 Author Share Posted February 12, 2013 Thx Dear Bro this setting not work bt i used another Lisp command. ;/* *************************************************************** */ ;/* *********** File name : p.lsp *********** */ ;/* *********** Written by : Farzad Rashvan *********** */ ;/* *********** Dec. 1998. Kyrgyzestan.Berlin.4 *********** */ ;/* *************************************************************** */ (princ "\nNew Function : G") (defun C:G() (setvar "CMDECHO" 0) (graphscr) (setvar "osmode" 1) (princ "\nSelect Extended Line ...") (setq b (getpoint)) (setq x1 (car b)) (setq y1 (cadr b)) (setq z1 (caddr b)) (setq y1 (- y1 4.05)) (setq y2 (+ y1 43.0)) (setq y3 (+ y1 3.0)) (setvar "osmode" 0) (command "color" "white") (command "linetype" "s" "acad_iso13w100" "") (command "style" "Times New Roman" "" 0.27 1 0 "n" "n" "n") (princ "\nSelect PolyLine:") (setq fr (entget (car (entsel)))) (setq r (cdr (assoc 90 fr))) (setq tgo 10) (setq lx 0) (setq i 0) (repeat r (setq i (+ i 4)) (setq hr (assoc 10 fr)) (setq d (cons 1111 000)) (setq hrr (cdr hr)) (setq fr (subst d hr fr)) (terpri) (setq h (car hrr)) (setq k (cadr hrr)) (setq xyd1 (list h k)) (setq xyd2 (list h y3)) (setq k (/ k 1)) (if (/= 1 tgo) (if (< (* h lx) 0) (progn (setq yoo (+ ly (/ (* lx (- ly k)) (- h lx)))) (command "color" "White") (setq pox (list 0.25 (+ y2 0.25))) (setq poy (list 0.25 (+ y1 0.25))) (setq syo (rtos yoo 2 3)) (setq htest (rtos k 2 3)) (setq lxtest (rtos ly 2 3)) (command "text" pox "0" "0.00") (command "text" poy "0" syo) (setq tgo 1) ) ) ) (if (/= 0 h) (progn (command "color" "green") ) ) (setq sx (rtos (abs h) 2 3)) (setq sy (rtos k 2 3)) (setq py (list (+ h 0.2) (- y1 -1.7))) (setq px (list (+ h 0.2) (- y2 43.1))) (command "color" "red") (command "text" px "90" sx) (command "text" py "90" sy) (setq lx h) (setq ly k) ) (princ) (redraw) ) Quote Link to comment Share on other sites More sharing options...
krkan Posted February 13, 2013 Share Posted February 13, 2013 Hello, This topic is not a place here, but I'll try. I have the drawing closed polyline (road corridor) and the many lines that intersect. Is there a routine that only selecting polylines, it automatically added to each section vertices with lines. I used some routines, but at close range it does not add vertices. there are plenty of data and the problem has to do manually. thank you Quote Link to comment Share on other sites More sharing options...
