Results 1 to 2 of 2
Thread: About Block
    Junior Member
    AutoCAD LT 2011
    Sep 2012
    Default About Block
    How do I update a Block from another drawing, from an external file?
    Full Member
    AutoCAD 2010
    Dec 2012
    well when you open the file autocad will ask you what you want to do with that block and the block editor will be available for that purpose.
    In other word when u hit the insert key the browse option will pop-up and u select any file from there where the block will available and u can edit from there.
  1. Attribute in title block exists in BLock Editor but not in Project.
    By Pawnsurfer in forum AutoCAD Drawing Management & Output
    Last Post: 19th Feb 2015, 09:10 pm
  2. insert block at distance & angle from first block, then repeat until stopped
    By BudPerry in forum AutoLISP, Visual LISP & DCL
    Last Post: 26th Jul 2012, 04:45 pm
  3. Replies: 16
    Last Post: 25th May 2011, 06:56 pm
  4. How to match Hidden line scale in a block and out of the block
    By gururajendrak in forum AutoCAD General
    Last Post: 25th Jun 2009, 04:40 pm
  5. Block Attribute answers ability to change block Physical Attributes??
    By Kaidoz in forum AutoLISP, Visual LISP & DCL
    Last Post: 19th Mar 2008, 10:25 pm
