Ok, I will try and keep this as simple and straight forward as I can.
I want take a block that is nothing but a rectangle and add stretch actions to the length and width. I then want to add an attributes tag to the block to define the length and width. I want the value of the attribute to be a field that is dynamically updated based on the strecth parameters. So if I stretch the length from 12 to 24 the attribute for length would change from 12 to 24.
I know how to do all the dynamic block stuff, I know how to use fields and attributes, but I can't figuer out how to make an attributes value update based on dynamic parameters/actions within a block.
TIA for any help!
I have enclosed a sample block that updates the value based on the distance property of the "distance" and "distance1" parameter.
In the attribute definition value field, I right clicked and selected Insert field. The I made the following changes to the field object.
Field Category: Objects
Field Name: Object
Select the Linear parameter
Select the Property: Distance.
Save the block and Insert it.
Remember to type REGEN to regen the drawing after you stretch the object.
http://www.occc.edu/jhelton/dblock.dwg
  • 3 weeks later...
Thanks John. I know it's a little late but it's been crazy around here the last few weeks. Thanks Again!
What you may not know is that a field can reference a parameter in a dynamic block just as it can reference an attribute.
Before you start, you may wish to rename your distance parameters in the block definition so they are easy to find in the field menu. (suggestion: width, height)
type ATT
to the right of VALUE hit the INSERT FIELD button
under FIELD CATEGORY choose OBJECTS
use select objects button and pick block you wish to reference
the name of your parameters should be in the list. Simply pick which one you wish to use and update the rest of attribute.
repeat for multiple attributes.
Once you've created a block using your new attributes, the fields will automatically update after a regen should you adjust the size of the block.
I hope that helps.
  • 2 years later...
I am not super familiar with dynamic blocks, but I know what I need to do could only be possible through their concept. This idea of an automatically adjusting an object and its readout like this could really come in handy.
Do you feel that you could make a block, say a donut, that when put at a certain location in model space could automatically fill in a table in paper space based on it x,y coordinate? If so, would you have to hyperlink each block to each field in the table.
Thanks for any help you can offer.
  • 7 years later...
Hi all ... I am having the same issue but I do not know if I need to open up a new Thread or if I can ask it in this one ? It is related to the same thing
  • 5 months later...
Field Name: Object
Thanks Prof, I have been dabbling with this one by stretching an object and using it's length but when I changed visibility states the object length value was lost to complication. Your explanation is one that I would not have recognized without reading your post. Thanks again.
TIA for any help!
You might use nomenclature in the attribute tag that helps you to remember how you defined the field I found I could use object: select a line of the rectangle/length and get a returned value but the point is define a couple of attributes and select the field by more than one method to see what you get....
Best of luck
Field Name: Object
Wow small world I was in your class way back in 1999.
