Lentezza Posted February 26, 2013 Share Posted February 26, 2013 Hello, it´s me again... I have the following situation to resolve: I am in the process of drawing a corner bench which later on I will produce from solid wood. The backrests of the bench are simple boards. Now I came to the point where I need to trim these boards to make them form the corners. To be able to gain the right angles and measures I am drawing the hole thing in 3d (and also for presenting it to my customers). Here is a profile drawing from the bench construction to make it a bit easier to understand: I extracted two of the intersecting boards from my drawing, as seen in the following drawing: [ATTACH]40478[/ATTACH] I made a simple sketch to demonstrate the result I want to achieve. [ATTACH]40478[/ATTACH] Pleas let me know wether I have been clear about my request. Greetings Len Quote Link to comment Share on other sites More sharing options...
Lentezza Posted February 26, 2013 Author Share Posted February 26, 2013 I think the above is to vague to be understandable.... Here is the full drawing: Bench full.dwg Quote Link to comment Share on other sites More sharing options...
JD Mather Posted February 26, 2013 Share Posted February 26, 2013 How are you attempting to do attachments here (Go Advanced)? Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 26, 2013 Share Posted February 26, 2013 I would have swept or extrude the profile of one of the simple backrest boards along a path defining the center line of the entire back of the bench including the angled portion. Quote Link to comment Share on other sites More sharing options...
Lentezza Posted February 26, 2013 Author Share Posted February 26, 2013 @ JD Oops something went wrong.. I did it the way you propose initially but then had to shut down my computer and copy-pasted the text including the attachments... I tried if I could still open them. It worked but probably does so only on my computer...? Quote Link to comment Share on other sites More sharing options...
JD Mather Posted February 26, 2013 Share Posted February 26, 2013 Slice with Surface http://home.pct.edu/~jmather/content/CAD238/AutoCAD%202007%20Tutorial%208.pdf Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 26, 2013 Share Posted February 26, 2013 One bench back rail. So slicing no dicing. Quote Link to comment Share on other sites More sharing options...
Lentezza Posted February 26, 2013 Author Share Posted February 26, 2013 Beautiful! I had thought there must be a simple solution to that! Thank you! Quote Link to comment Share on other sites More sharing options...
Lentezza Posted February 26, 2013 Author Share Posted February 26, 2013 Now I am only wondering whether there will be a difference between the results of this two methods when it comes to extracting values...?? Quote Link to comment Share on other sites More sharing options...
JD Mather Posted February 26, 2013 Share Posted February 26, 2013 Examine the solutions carefully - there are two different joints - a lap joint in one and a miter joint in the other. You need to decide. Quote Link to comment Share on other sites More sharing options...
Lentezza Posted February 26, 2013 Author Share Posted February 26, 2013 Doing the sweep method I automatically got the mither joint - the one I wanted. Thanx JD Here´s the next one ;-) For the corner peace of the seating surface I´d like to apply the sweeping and slicing. To make it as simple as possible I´d like to use the green extruded part for slicing the swept part of the seating surface (brown). But I don´t know how.... With the SLICE command I can´t choose such an object as the slicing one... [ATTACH]40487[/ATTACH] Quote Link to comment Share on other sites More sharing options...
