rodrigo_sjc_sp Posted March 7, 2013 Posted March 7, 2013 Hi I have this code (setq i 0) (setq sel (ssget '((0 . "LWPOLYLINE")))) (repeat (sslength sel) (setq entpl (ssname sel i)) (setq lentpl (entget entpl)) (setq layerpl (cdr (assoc 8 lentpl))) (setq aberto (cdr (assoc 70 lentpl))) (if (member (strcase layerpl) lista_layers_hatch) (progn (setq j 0) (setq lis_coords '()) (repeat (length lentpl) (if (= (car (nth j lentpl)) 10) (setq lis_coords (append lis_coords (list (cdr (nth j lentpl))))) ) (setq j (+ j 1)) ) (print "008") (setq seldiv (ssget "wp" lis_coords (list (cons 0 "LWPOLYLINE") (cons 8 "Ptest,Ptest2") ) ) ) (print "009") In Windows xp , vista is ok, but in windows 8 64 bits i have the return "008" ; erro: sequence of characters of mode ssget incorrect Is it the windows 8 64? Quote
Lee Mac Posted March 7, 2013 Posted March 7, 2013 Try: (ssget "[color=red][highlight]_[/highlight][/color]WP" lis_coords ... ) Quote
rodrigo_sjc_sp Posted March 7, 2013 Author Posted March 7, 2013 Lee, It worked What is the difference between "wp" and "_WP" thank you Quote
Lee Mac Posted March 7, 2013 Posted March 7, 2013 What is the difference between "wp" and "_WP" Firstly, note that the modes are case-insensitive, so "_wp" would also work (but I personally prefer to use uppercase for ssget mode strings). The underscore allows for non-English versions of AutoCAD (since the WP mode may use different initials in a different language). See here for more information on command prefixes. Quote
rodrigo_sjc_sp Posted March 7, 2013 Author Posted March 7, 2013 Lee, You're right. The system was developed for autoCad English and was running a version of autoCad Portuguese The former developer did not put the (_), now fix already in the system. thank you Quote
