trussman Posted March 13, 2013 Share Posted March 13, 2013 I am wanting to know if it is possible using inventor 2013 and how to create 2 parts that sleeve together and be able to be moving parts through inventor? Like I want to have per say one round tube straight and have several sections of another round tube with the inside dimensions to match the outside dimensions of the first tube placed in different locations along the first tube and for it to be a moving part through inventor is this possible and how can I do this I am presuming that they would have to be separate parts that are assembled and I was wanting to use the frame generator for those parts also can someone help? Quote Link to comment Share on other sites More sharing options...
JD Mather Posted March 13, 2013 Share Posted March 13, 2013 Yes, this can be done (quite easily). Kinematics is one of the main reasons for moving beyond AutoCAD to Inventor. Quote Link to comment Share on other sites More sharing options...
trussman Posted March 14, 2013 Author Share Posted March 14, 2013 excelent now how to do it lolis there a simple tut I can follow and I mean my type of simple lol as you know Quote Link to comment Share on other sites More sharing options...
TenSecond408 Posted March 15, 2013 Share Posted March 15, 2013 excelent now how to do it lolis there a simple tut I can follow and I mean my type of simple lol as you know Im not an expert at with Inventor, but what your trying to do it fairly simple (the way I would do it atleast) The way i would do it: 1: Create new part, draw your main tube that will be sliding inside the sleeves, save part 2: Create new part, now draw your sleeves, with the ID matching the OD of the main tube, save part 3: Create an assembly 4: Place main tube into the assembly 5: Place sleeves into assembly 6: make a constraint: "mate" and use the concentric axis of both the main tube and the sleeves (this will constrain the tube and the sleeves to the same center axis) 7: make a constraint for each sleeve: "mate" select the face of the first sleeve and the face of the 2nd sleeve ( this will constrain the sleeve face to the sleeve face) then you can apply offsets to space each sleeve apart from each other accordingly Hope this helps AJ Newman Quote Link to comment Share on other sites More sharing options...
trussman Posted March 16, 2013 Author Share Posted March 16, 2013 Ok will this work with frame generator? Like I have 2 different skeleton parts on is for the main tube frame and the other if for the sleeve frame as there are more than just the main tube and the sleeve tube thats attached to them using sketch skeleton method. When you say "mate" I can only find imate in the ribbon where exactly is mate if you dont mean imate? Quote Link to comment Share on other sites More sharing options...
trussman Posted March 17, 2013 Author Share Posted March 17, 2013 Ok can not seam to get constrain using frame generated parts is there not away of doing so? Quote Link to comment Share on other sites More sharing options...
JD Mather Posted March 17, 2013 Share Posted March 17, 2013 Frame generated parts are grounded by default. Attach your assembly here. Forget iMate - that is not what it is for. On the Position tab select Constrain for assembly constraints (including Mate). But as I stated - Frame Generator parts are grounded, so this will require a slightly different technique. Quote Link to comment Share on other sites More sharing options...
trussman Posted March 17, 2013 Author Share Posted March 17, 2013 here it is I had to zip it for it to work [ATTACH]40864[/ATTACH] Quote Link to comment Share on other sites More sharing options...
JD Mather Posted March 17, 2013 Share Posted March 17, 2013 An assembly file (*.iam) is worthless without part files (*.ipt). And iam file is nothing more than a list of hyperlinks to the part files and a record of assembly constraints. The only thing in your zip file is the iam file. Quote Link to comment Share on other sites More sharing options...
trussman Posted March 17, 2013 Author Share Posted March 17, 2013 [ATTACH]40866[/ATTACH][ATTACH]40865[/ATTACH] here are the other files Quote Link to comment Share on other sites More sharing options...
JD Mather Posted March 17, 2013 Share Posted March 17, 2013 You have placed both skeletons into the same assembly. Don't do this. In the real world each would be a sub-assembly assembled into main assembly. Do the same thing in Inventor. So Create the ladder truss as one assembly. Create the sleeved ladder truss as another assembly. These will both be sub-assemblies. Start a new assembly file and place the ladder truss sub-assembly. place the sleeved ladder truss sub-assembly. Mate Axis to axis (looks like twice). I think you will then need to add a Mate to limit the range of motion (expand the Mate constraint dialog), but not sure where you are going with this. I will try to post an example tomorrow. Quote Link to comment Share on other sites More sharing options...
trussman Posted March 17, 2013 Author Share Posted March 17, 2013 OK thanks for that help I am intending on creating a collapsible triangle truss I will try out the method you mentioned here Quote Link to comment Share on other sites More sharing options...
trussman Posted March 18, 2013 Author Share Posted March 18, 2013 OK I have managed the first constraint but I see now I need to adjust some parts of the skeletal model sleeved so that the parts all fit correctly I have attempted this already but cant seam to unconstrained it to make the appropriate changes I supose though I could just start again though Quote Link to comment Share on other sites More sharing options...
JD Mather Posted March 18, 2013 Share Posted March 18, 2013 It sounds to me like you need to open the skeleton for the sub assembly and edit as needed. All will update. Quote Link to comment Share on other sites More sharing options...
trussman Posted March 18, 2013 Author Share Posted March 18, 2013 It sounds to me like you need to open the skeleton for the sub assembly and edit as needed.All will update. Yeah I worked that out its just figuring out what all I can do with inventor and what I cant do is my problem lol Quote Link to comment Share on other sites More sharing options...
trussman Posted March 18, 2013 Author Share Posted March 18, 2013 OK you mentioned a constrain for limited motion I presume using the motion tab in the constraint dialog I see you mentioned expanding the dialog and I did I see there is a minimum and a maximum limits there do I enter in degrees to those and I also see the limits entry boxes grey out on me when I go to the motion tab in the dialog box. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted March 18, 2013 Share Posted March 18, 2013 I don't think you need the Motion tab for this design. A simple Mate. You can set min position, max position and resting position (offset distances). Min position is often the resting position. Quote Link to comment Share on other sites More sharing options...
trussman Posted March 18, 2013 Author Share Posted March 18, 2013 OK I got it working the motion stops where I want it on both sides of the main frame thanks Quote Link to comment Share on other sites More sharing options...
trussman Posted March 18, 2013 Author Share Posted March 18, 2013 OK So moving on and I do apologize again for my constant questions on each and every step along this path and I thank you for being so helpful and patient. Is there away for me to make a sort of blue print from this? with weld placement and stuff Quote Link to comment Share on other sites More sharing options...
JD Mather Posted March 19, 2013 Share Posted March 19, 2013 If you want welds you should see a Convert to Weldment on your Ribbon. From there you will have to figure out the tools. For drawing start a new *.idw (Inventor Drawing) or *.dwg. Place Base View selecting your assembly file. Place projeced 2d views from the base view. Dimension on the Annotation tab. Quote Link to comment Share on other sites More sharing options...
