How can i use the (array ) command in Autolisp ???
سبع الليل
بسم الله الرحمن الرحيم
الحمد لله رب العالمين ، و الصلاة و السلام على أشرف المرسلين ، أشهد أن لا إله إلا الله ، و أن محمداً رسول الله ، و أن عيسى المسيح عبد الله و رسوله و كلمته ألقاها إلى مريم ،، و بعد :
Hii Guys and cad msters :
I really love you , and happy to join this great forum :)
(command "circle" p1 "d" d1 "")
(setq soda ( entlast))
(command "hatch" "s" soda "")
(command "array" "l" "" "r" "1" "10" "150" "")
This will make an array for a circle along ( + X ) direction
What shall I do if i need the array in (-X) direction ,,,, or if i want to specify an angle for the array ??
(Defun c:demo (/ soda p1 d1 dir ang)
 (setq p1 (Getpoint "\nPick point:"))
 (setq d1 (getdist "\nEnter Circle Diameter size: "))
 (setq soda (ssadd)) ;<-- empty selection set
 (ssadd (entlast) soda) ;<--add  circle to selection set
 (ssadd (entlast) soda);<--add  hatch to selection set
 ;;; 	option for direction	;;;
 (initget 1 "R L")
 (setq dir (getkword "\nChoose Direction [Left/Right]: "))
 (command "array"
          soda  ""  "r" "1" "10"
          (if (eq dir "L")
            (- 150)
            150
Now whats the deal with the "angle" ? polar array angle? or directional angle?
My approach . :)
(defun c:TesT (/ *error* GrLeader c s p d g pt)
;;; Author : Tharwat Al Shoufi 14. 03. 2013 ;;;
 (defun *error* (x) (redraw) (princ "\n*Cancel*"))
 (defun GrLeader (pt d w / p1 p2 p3 p4)
   (if (eq "R" w)
     (setq p1 (polar pt (* pi 0.5) (* d 4.))
           p2 (polar p1 (/ pi 4.) (* d 4.))
           p3 (polar p2 pi d)
           p4 (polar p2 (* pi 1.5) d)
           p2 (polar p1 (* (/ pi 4.) 3.) (* d 4.))
           p3 (polar p2 0. d)
   (grvecs (list -1 pt p1 p1 p2 p2 p3 p2 p4))
 (setq d 75.) ; Radius of the Circle
 (if (and (setq s (ssadd)
                p (getpoint "\n Specify Circle insertion point:")
          (ssadd (setq c (entmakex (list '(0 . "CIRCLE") (cons 10 p) (cons 40 d)))) s)
   (progn (command "_.hatch" "s" c "")
          (ssadd (entlast) s)
          (while (eq (car (setq g (grread t 15 0))) 5)
            (redraw)
            (princ "\r Specify the Direction ")
            (if (> (car (cadr g)) (car p))
              (Grleader p d "R")
              (GrLeader p d nil)
          (cond ((and (eq 3 (car g)) (> (car (cadr g)) (car p))) (command "_.array" s "" "r" "1" "10" 150))
                ((and (eq 3 (car g)) (< (car (cadr g)) (car p))) (command "_.array" s "" "r" "1" "10" -150))
                (t (princ "*Cancel*"))
 (redraw)
 (princ "\n Written by Tharwat Al Shoufi")
Really ::::
This is a great forum
Thank you all ,, Every day i learn new something ...
 (initget 1 "R L")
 (command "array"
          (if (eq dir "L")
            (- 150)
            150
ssadd is new for me ,,, but really it is a great and very useful & important .... thank you mr pBe very much
what i need is the directional angle
My approach . :)
   (if (eq "R" w)
           p3 (polar p2 pi d)
           p3 (polar p2 0. d)
          (ssadd (entlast) s)
            (redraw)
              (Grleader p d "R")
              (GrLeader p d nil)
 (redraw)
Thank you eng. Tharwat
but there is somethings i can't understand it
any way i am trying to understand and use
thank you mr pBe very much......
If you want to maintain the use of the command ARRAY, you can twist the UCS like so:
 (setq d1 (getdist p1 "\nEnter Circle Diameter size: "))
 (setq d (getdist  "\nEnter Distance between circles: "))
 (setq it (getint "\nEnter Number of itmes: "))
 (setq p2 (getpoint p1 "\nPick point for direction "))
 (command "_UCS" "_3P" p1 p2 "" "")
 (command "array"
          soda  ""  "r" "1" it  d  )
 (command "_ucs" "_World")
There's probably an angle prompt on newer version of CAD for array. :)
Or you can use the command COPY:
(Defun c:demo2 ()
(setq soda (ssadd))
 	(setq ang (angle p1 p2))
 	(repeat it
         	(setq p2 (polar p1 ang d))
	(command "_copy" soda "" "_non" p1 "_non" p2)
         	(setq p1 p2)
Both codes doesn't require a negative value for direction at all. play around with the plain and simple snippets until you get the hang of it, then you can start experimenting with codes like the one posted by tharwat.
HTH
 (command "array"
(Defun c:demo2 ()
(setq soda (ssadd))
 	(repeat it
         	(setq p1 p2)
HTH
Mr pBe
really , you Are awesome great man
thank you a lot a lot a lot a lot a lot a lot a lot a lot a lot a lot a lot a lot
