Lentezza Posted March 15, 2013 Share Posted March 15, 2013 Hello, been posting a view times already during this project.... Here is what I am working on: For being able to retrieve dimensions and angles from the drawing I started by redrawing the back rails of the bench with an rectangle profle. This is where the problem appeared.... Sweeping worked perfectly for the lower two of the rails: But it didn´t for the upper one....: As you can see in the drawing Sweeeep.dwg I put the profile on both ends of the rail. I tried sweeping from both ends - same result. (Instead when I did the drawing with the true profile of the rails sweeping worked fine only from one of the endings...) ????? Looking forward for your suggestions!! Len Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 15, 2013 Share Posted March 15, 2013 I would just extrude the profile using the path option and be done with it. Why make it more complicated than it needs to be? Quote Link to comment Share on other sites More sharing options...
Lentezza Posted March 15, 2013 Author Share Posted March 15, 2013 Thank you again, ReMark!! You are right, why make it more complicated..... Still I would be curious to find out why the SWEEP of this one part did not work.... Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 15, 2013 Share Posted March 15, 2013 I don't know what causes Sweep to sometimes produce less than the expected result. It's mystery I haven't got the time to try and solve. When I am retired and have nothing better to do maybe I'll delve into it. Until then it is a matter of getting the job done as quickly as one can with the tools available to us. When one tool fails it's time to try another. Quote Link to comment Share on other sites More sharing options...
Lentezza Posted March 15, 2013 Author Share Posted March 15, 2013 I understand. Quote Link to comment Share on other sites More sharing options...
hoss Posted March 15, 2013 Share Posted March 15, 2013 Use Rotate3d and pick the end profile ( rectanagle) use mid of top and mid of buttom line and rotate by 180 then use sweep worked for me Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 15, 2013 Share Posted March 15, 2013 No rotation. Extrude. Done. Quote Link to comment Share on other sites More sharing options...
Lentezza Posted March 19, 2013 Author Share Posted March 19, 2013 For a rookie like me it´s good to see that working with CAD needs the use of workarounds even if you have reached a higher level of dominating it...(-; Quote Link to comment Share on other sites More sharing options...
f700es Posted March 19, 2013 Share Posted March 19, 2013 Oh there are usually 3 to 4 ways to complete a task. Figuring out the best way for "you" is the trick at times. Quote Link to comment Share on other sites More sharing options...
