Amail Posted March 15, 2013 Posted March 15, 2013 I'm trying to make a watermark visible when the "Approved" attribute in the titleblock is blank and invisible when the attribute has a value. I want the logic to be: =(If (isblank (attrib)),"In Process","") I can't seem to make this work. Alternatively, I could have the watermark on a layer whose visibility is controlled by the presence or absence of a value in that attribute. Any ideas? Quote
Tharwat Posted March 15, 2013 Posted March 15, 2013 Welcome to CadTutor . From Help Document . Check the DXF 70 of the attribute definition . 70 Attribute flags: 1 = Attribute is invisible (does not appear) 2 = This is a constant attribute 4 = Verification is required on input of this attribute 8 = Attribute is preset (no prompt during insertion) Quote
Amail Posted March 15, 2013 Author Posted March 15, 2013 Welcome to CadTutor . From Help Document . Check the DXF 70 of the attribute definition . No, that's not it. My problem isn't the visibility of the attribute. I want the visibility of a field in the drawing to be controlled by the contents of the attribute. Basically, I want there to be a big "In Process" watermark permanently across the drawing UNLESS somebody has entered their initials in the "Approved" box. I want this automated, not something that a user has to control via plot stamp or the like. Quote
BIGAL Posted March 15, 2013 Posted March 15, 2013 We have a "Issued for construction" lisp that updates all layout tabs so this method could change the "in progress " pretty easy, it uses a auto change an attribute value in a block. More than happy to post link if this would be usefull. Quote
xces Posted February 25, 2016 Posted February 25, 2016 We have a "Issued for construction" lisp that updates all layout tabs so this method could change the "in progress " pretty easy, it uses a auto change an attribute value in a block. More than happy to post link if this would be usefull. that would be helpful Quote
