sadhu Posted March 28, 2013 Posted March 28, 2013 I need to make a list of blocks present in the drawing that are in front of reference block (front-list) and a second list of blocks that are behind (back-list). The front-list needs to be ordered left-to-right (clockwise) respect to the reference block while the back-list has to be ordered right-to-left(anticlockwise) . The reference block is a rectangle with an arrow pointing towards the front face. When the arrow (face) points down its rotation angle (dxf 50) is zero. I thought of comparing the rotation angle (dxf 50) of the reference block and the other blocks (insertion point - dxf 10) to get the front-list and back-list but I'm missing some fundamental mathematics/geometry and lisp comands. All help , thoughts and ideas to investigate is appreciated. Quote
sadhu Posted March 29, 2013 Author Posted March 29, 2013 This is how I'm proceeding. See attached file too. (defun C: test(/) (setq blklst (ssget "X" (list '(0 . "INSERT")))) (setq numblk (sslength blklst) blk_cnt 0) (while (< blk_cnt numblk) (setq en (ssname blklst blk_cnt)) (setq enlist (entget en)) (cond ((and (= (cdr (assoc 0 enlist)) "INSERT")(= (cdr (assoc 2 enlist)) "ITEMS")) "(get ITEMS angle [item_angle]) (compare with REF_BLK angle [ref_blk_angle]) [( if ref_blk_angle + 270° > Item_angle > ref_blk_angle + 90°) then add to back_list] [( if ref_blk_angle + 90° > Item_angle > ref_blk_angle - 90°) then add to front_list] " )) (setq blk_cnt (+ 1 blk_cnt)) )) TEST.dwg Quote
David Bethel Posted March 29, 2013 Posted March 29, 2013 This could be a starting point: [b][color=BLACK]([/color][/b]defun c:fblst [b][color=FUCHSIA]([/color][/b]/ ss rn rd rp sa ea ia i en ed ip an[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]while [b][color=NAVY]([/color][/b]not rn[b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]princ [color=#2f4f4f]"\nSelect Reference INSERT ..."[/color][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]setq ss [b][color=MAROON]([/color][/b]ssget '[b][color=GREEN]([/color][/b][b][color=BLUE]([/color][/b]0 . [color=#2f4f4f]"INSERT"[/color][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]if [b][color=MAROON]([/color][/b]= [b][color=GREEN]([/color][/b]sslength ss[b][color=GREEN])[/color][/b] 1[b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]setq rn [b][color=GREEN]([/color][/b]ssname ss 0[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]setq rd [b][color=NAVY]([/color][/b]entget rn[b][color=NAVY])[/color][/b] rp [b][color=NAVY]([/color][/b]cdr [b][color=MAROON]([/color][/b]assoc 10 rd[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] sa [b][color=NAVY]([/color][/b]cdr [b][color=MAROON]([/color][/b]assoc 50 rd[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] ea [b][color=NAVY]([/color][/b]+ sa pi[b][color=NAVY])[/color][/b] ia [b][color=NAVY]([/color][/b]if [b][color=MAROON]([/color][/b]> sa ea[b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]+ [b][color=GREEN]([/color][/b]- [b][color=BLUE]([/color][/b]* 2 pi[b][color=BLUE])[/color][/b] sa[b][color=GREEN])[/color][/b] ea[b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]- ea sa[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]setq rl [b][color=NAVY]([/color][/b]ssadd[b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]setq fl [b][color=NAVY]([/color][/b]ssadd[b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]and [b][color=NAVY]([/color][/b]setq ss [b][color=MAROON]([/color][/b]ssget [color=#2f4f4f]"X"[/color] '[b][color=GREEN]([/color][/b][b][color=BLUE]([/color][/b]0 . [color=#2f4f4f]"INSERT"[/color][b][color=BLUE])[/color][/b][b][color=BLUE]([/color][/b]2 . [color=#2f4f4f]"ITEMS"[/color][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]setq i 0[b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]while [b][color=MAROON]([/color][/b]setq en [b][color=GREEN]([/color][/b]ssname ss i[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]setq i [b][color=GREEN]([/color][/b]1+ i[b][color=GREEN])[/color][/b] ed [b][color=GREEN]([/color][/b]entget en[b][color=GREEN])[/color][/b] ip [b][color=GREEN]([/color][/b]cdr [b][color=BLUE]([/color][/b]assoc 10 ed[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] an [b][color=GREEN]([/color][/b]angle rp ip[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]if [b][color=GREEN]([/color][/b]> sa an[b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]setq an [b][color=BLUE]([/color][/b]+ an pi pi[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]if [b][color=GREEN]([/color][/b]< sa an [b][color=BLUE]([/color][/b]+ sa ia[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]ssadd en rl[b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]ssadd en fl[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]prin1[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b] The PICKSET rl contains the entities that are to the 'rear', fl to the 'front' -David Quote
Lee Mac Posted March 29, 2013 Posted March 29, 2013 Another quick example, very similar to David's method: (defun c:orderblocks ( / 2pi ang blk bot ent inc ins rot sel top ) (if (and (princ "\nSelect Reference Block: ") (setq blk (ssget "_+.:E:S" '((0 . "INSERT")))) (setq sel (ssget "_X" '((0 . "INSERT") (2 . "ITEMS")))) ) (progn (setq blk (entget (ssname blk 0)) ins (cdr (assoc 10 blk)) rot (cdr (assoc 50 blk)) 2pi (+ pi pi) ) (repeat (setq inc (sslength sel)) (setq ent (ssname sel (setq inc (1- inc))) ang (rem (+ 2pi (- (angle ins (cdr (assoc 10 (entget ent)))) rot)) 2pi) ) (if (< 0 ang pi) (setq bot (cons (cons ang ent) bot)) (setq top (cons (cons ang ent) top)) ) ) (setq bot (vl-sort bot '(lambda ( a b ) (< (car a) (car b)))) top (vl-sort top '(lambda ( a b ) (> (car a) (car b)))) ) [color=green](getstring "\n-- 'Top' blocks --\n<Next>") (while top (redraw (cdar top) 3) (getstring "\n<Next>") (redraw (cdar top) 4) (setq top (cdr top)) ) (getstring "\n-- 'Bottom' blocks --\n<Next>") (while bot (redraw (cdar bot) 3) (getstring "\n<Next>") (redraw (cdar bot) 4) (setq bot (cdr bot)) )[/color] ) ) (princ) ) The highlighted section is purely to display the result. Quote
sadhu Posted March 29, 2013 Author Posted March 29, 2013 Thank you David, thank you Lee. Just what I needed. You guys are real good. Lee, your code does the ordering too and the graphic effect is helpful. Thanks again. Quote
