rodrigo_sjc_sp Posted April 8, 2013 Share Posted April 8, 2013 How to draw a rectangle to make a frame on a block. I already have the information in this block - ssname and entget (setq pline_ent (ssname selpline i)) (setq lis_ent (entget pline_ent)) i try , but not work (setq valor2 (cdr(assoc 10 (entget pline_ent)))) pmin = ???? pmax = ???? (setq oldosmode (getvar "osmode")) (setvar "osmode" 0) (command "_rectangle" "_from" pmin "@3,-3" "_from" pmax "@-3,3") (setvar "osmode" oldosmode) (princ) How to determine the values of Pmin and PMax? Based on the selected block, or have to make a rectangle on the block, like a frame. Thanks Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted April 8, 2013 Share Posted April 8, 2013 Look into (vla-get-boundingbox) function applied to block VLA-Object to obtain pmin and pmax... Quote Link to comment Share on other sites More sharing options...
rodrigo_sjc_sp Posted April 8, 2013 Author Share Posted April 8, 2013 (edited) Marko , Thanks for the tip! I found this Post http://www.cadtutor.net/forum/showthread.php?54046-Bounding-Box-LISP and it worked Thank you Edited April 8, 2013 by rodrigo_sjc_sp Quote Link to comment Share on other sites More sharing options...
