chris2x1 Posted April 25, 2013 Share Posted April 25, 2013 Hi, I have created a standard project for my company to use, so we can start every project from same set of drawings and either add/delete components depending on job spec. For this i name all the Drawaings TSM100001,TSM100002,TSM100003 etc when i make a copy of the folder and add it to acade manager, it works find but then i right click on a drawing file and go to drawing properties, i have change under IEC - Style Designators >> Project code TSM100001 to say HHT1434601 for each drawing which takes forever, i tried editing the database but it doesnt seem to write back to acade only reads acade. Also i some components say an instrument with tag 1234E, I then have a child of this instrument on another page which is 1234E, i then have 4 wires 2 at instrument side and 2 at terminal side and i want to make all them siblings with tag 1234E, but i am having to right click and use edit componenet with each wire to assign it the tag, is there any way to do all five in one go? Quote Link to comment Share on other sites More sharing options...
chris2x1 Posted April 25, 2013 Author Share Posted April 25, 2013 Hi, I have found the solution to the parent child issue. Under Schematic>> Edit Components>> Find/Edit/Replace Component Text The quick command is AEFINDCOMPTEXT. Still looking for initial problem's solution though Quote Link to comment Share on other sites More sharing options...
