mikekmx Posted May 15, 2013 Share Posted May 15, 2013 (edited) Hi all, i'm an idiot. i've been plaing with my CUI and found there were a lot more visual styles than i thought so added a few to the dashboard to try out. trouble is, a few have similar names and the same icon and now my realistic that i liked is not available. now it's kinda semi-transparent....and really annoying. before it was totally opaque. the same with my 'conceptual'...i can see far too much geometry. I know it's a long-shot....and it may be a setting in options as well cos i have been experimenting there......anyone know what has done it & how to get it back please? btw i don't have a personal CUI or whatever the procedure is....i just modify the main one when inclined. i've made a toolabr with ALL the listed visual styles on it and gone through them all but none of them gets it back to the opaque version. ^^^ this is in model space only. viewing from paper space it's the same as it always was. Edited May 15, 2013 by mikekmx Quote Link to comment Share on other sites More sharing options...
edwinprakoso Posted May 16, 2013 Share Posted May 16, 2013 I don't have the same version as you do. So I can't check how to set it back. But would it be OK if you reset the profile or even 'reset settings to default'? Please note that this will reset all customization. If you have customization, make sure you can set them back after resetting... Quote Link to comment Share on other sites More sharing options...
mikekmx Posted May 16, 2013 Author Share Posted May 16, 2013 I don't have the same version as you do. So I can't check how to set it back. But would it be OK if you reset the profile or even 'reset settings to default'? Please note that this will reset all customization. If you have customization, make sure you can set them back after resetting... thanks. i will try that soon. now i've got an new external HDD i can image my C drive, do any changes and if i don't like them, restore the image. it may come to a fresh install sometime soon anyway as my internal HDD is getting a bit noisy and i think it would be wise to replace soon. Quote Link to comment Share on other sites More sharing options...
rkent Posted May 16, 2013 Share Posted May 16, 2013 So go into the visual styles manager (visualstyles) and pick one that is close, adjust as needed, drag and drop that onto a tool palette. Quote Link to comment Share on other sites More sharing options...
mikekmx Posted May 16, 2013 Author Share Posted May 16, 2013 So go into the visual styles manager (visualstyles) and pick one that is close, adjust as needed, drag and drop that onto a tool palette. didn't know you could adjust them. thanks, i will investigate. Quote Link to comment Share on other sites More sharing options...
mikekmx Posted May 18, 2013 Author Share Posted May 18, 2013 i found where i can adjust the visual styles but the box for adjusting opacity is greyed out (and set to -60) in all but x-ray mode. i tried creating a new style based on x-ray which i thought i could then modify to be like realistic or conceptual but no luck.....the new style's opacity box is grey and at -60 i changed all other settings to see if opacity became enabled but nothing. any ideas? Quote Link to comment Share on other sites More sharing options...
Murph_map Posted May 19, 2013 Share Posted May 19, 2013 Look for a folder named UsersDataCache in the program files. I don't have 2008 but for map3d 2009 this is the path " C:\Program Files\AutoCAD Map 3D 2009\UserDataCache" That folder or in the support folder in there are copies of all the original files, just copy the cui file(s) into your Users data folder, Like so "C:\Users\murph\Application Data\Autodesk\AutoCAD Map 3D 2009\R17.2\enu\Support". (replace MURPH with your users name) Quote Link to comment Share on other sites More sharing options...
togores Posted June 3, 2013 Share Posted June 3, 2013 i found where i can adjust the visual styles but the box for adjusting opacity is greyed out (and set to -60) in all but x-ray mode. i tried creating a new style based on x-ray which i thought i could then modify to be like realistic or conceptual but no luck.....the new style's opacity box is grey and at -60i changed all other settings to see if opacity became enabled but nothing. any ideas? These settings depend on system variables whose name start with VS... Try loading the attached LSP file that will define a series of commands that will set visual styles with the settings for the default styles. This is an experiment, the settings for each variable match those in my system. But I can't swear they have not been tampered with VSTYLES.LSP Quote Link to comment Share on other sites More sharing options...
mikekmx Posted June 4, 2013 Author Share Posted June 4, 2013 These settings depend on system variables whose name start with VS...Try loading the attached LSP file that will define a series of commands that will set visual styles with the settings for the default styles. This is an experiment, the settings for each variable match those in my system. But I can't swear they have not been tampered with thank you very much Togores, i thought i'd replied before but it seems not. I have a spare 1/2hr so i'm trying them now..... Quote Link to comment Share on other sites More sharing options...
