mdbdesign Posted May 17, 2013 Share Posted May 17, 2013 (edited) This thread got start in: http://www.cadtutor.net/forum/showthread.php?75374-How-to-set-lineweight-to-flatshot-image and my last post in it was left without solution. I try to bump it by creating new thread in lisp section. Below is my last post with little modification: From now on I do all my project in 3D. Creating req'd views with flatshot from solid is not a big deal but changing lines to proper layer becoming big problem - time wise. If any of you, lisp guru's can possibly create program to change, in one shot,(product of flatshot) block entities to (hardcoded): - select block(s) - all hidden linetype multiple objects change to layer named "Hidden" and bylayer - all continuous linetype multiple object change to layer named "Object" and bylayer Color, line type control & line weight - bylayer as well. It will save me lots of time. Is it possible? Thank you. Edited May 17, 2013 by mdbdesign Quote Link to comment Share on other sites More sharing options...
