Results 1 to 2 of 2
    Forum Newbie
    AutoCAD 2013
    May 2013
    1
    Default Dynamic piping blocks - inserting and linking a flange block to a pipe block.
    Hi New to dynamic blocks and need a little help. I have created d/blocks for my different pipe sizes i.e one block with a dropdown to select the different sizes and have done the same for my flanges. now how do I link / insert the flange d/block to the piping block so that I can export the information into a material list later on.
    Senior Member
    Mike_Taylor's Computer Details
    Windows 7 64 Bit
    Intel I7 2600
    16GB DDR3
    Nvidia GTX 550
    2TB @ 7500 RPM
    1 TB @ 7500 RPM, 750GB @ 5200 RPM
    2 @ 24"
    Electrical
    Mike_Taylor's Discipline Details
    Rombald Inc. - CAD Designer and CAD Specialist
    Electrical
    Primarily Electrical Building Systems Design The "Lighting Guy"
    AutoCAD 2014
    Jul 2009
    Stratford, Ontario, Canada
    466
    Tools>Data Extraction Follow the instructions by creating a new .dxe file. When choosing the which object to grab the data from choose your dynamic block, from here it asks you to choose which items are to be extracted, your vibility state should be in there. From there uncheck all other boxes. You will then be prompted to choose an Excel output or a chart directly in your CAD file (or both). From here it will give you a quantity of each visibility type.
    In the attached example our switch block is named 1120, and we renamed our visibility state to switch type.
  1. Insert dynamic block from file with multiple dynamic blocks
    By BUrBaKy in forum AutoCAD Drawing Management & Output
    Last Post: 14th Nov 2012, 11:38 pm
  2. Enhanced Attribute Editor doesn't open after inserting dynamic block
    By smarcus3 in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 19th Mar 2012, 06:38 pm
  3. dynamic block for pipe
    By salman in forum AutoCAD General
    Last Post: 26th Jun 2010, 01:06 pm
  4. Inserting A Block w/ Dynamic Changing Text
    By idtjes3 in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Jun 2008, 01:56 pm
  5. Inserting Dynamic Block w/ Alignment Parameter
    By nemo in forum AutoLISP, Visual LISP & DCL
    Last Post: 14th May 2008, 09:38 pm
