wrha Posted May 28, 2013 Share Posted May 28, 2013 Dear Colleges is there any option to use (IF CLAUSES IN AUTOCAD TABLE) thanks alot Quote Link to comment Share on other sites More sharing options...
alanjt Posted May 28, 2013 Share Posted May 28, 2013 You can use DIESEL within fields, which can be used within TABLE cells, and DIESEL allows for if. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted May 28, 2013 Share Posted May 28, 2013 As far as I know, a Table formula cannot support an IF clause as available in Excel; however, you can alternatively use a DIESEL Field Expression which can use the IF function available in DIESEL. EDIT: Alan beat me to it. Quote Link to comment Share on other sites More sharing options...
wrha Posted May 29, 2013 Author Share Posted May 29, 2013 i use following formula it not working could you check =$(if,D12*E12/1000000,1[,0]C12*D12*E12/1000000) Quote Link to comment Share on other sites More sharing options...
wrha Posted May 29, 2013 Author Share Posted May 29, 2013 here is my xls sheet Volume of sandwich panel.xlsx Quote Link to comment Share on other sites More sharing options...
alanjt Posted May 29, 2013 Share Posted May 29, 2013 As far as I know, a Table formula cannot support an IF clause as available in Excel; however, you can alternatively use a DIESEL Field Expression which can use the IF function available in DIESEL. EDIT: Alan beat me to it. Yeah, but you had nice links. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted May 29, 2013 Share Posted May 29, 2013 i use following formula it not working could you check =$(if,D12*E12/1000000,1[,0]C12*D12*E12/1000000) I believe the 'then' & 'else' expressions of the DIESEL if function can only contain DIESEL expressions or fixed strings; I don't know if it is possible to reference table cells from within DIESEL expressions. Yeah, but you had nice links. Quote Link to comment Share on other sites More sharing options...
irneb Posted May 30, 2013 Share Posted May 30, 2013 I believe the 'then' & 'else' expressions of the DIESEL if function can only contain DIESEL expressions or fixed strings; I don't know if it is possible to reference table cells from within DIESEL expressions.Nope, you can't. Diesel fields don't allow nested fields, so referencing a cell address will also not be allowed. @wrha: What is the "if" condition you're looking for? Perhaps it could be translated to become 1 if true and 0 if false - then you could simply multiply it to the rest of the formula. Quote Link to comment Share on other sites More sharing options...
wrha Posted May 30, 2013 Author Share Posted May 30, 2013 Its formula could you check my xls sheet above Quote Link to comment Share on other sites More sharing options...
irneb Posted May 30, 2013 Share Posted May 30, 2013 Its formula could you check my xls sheet aboveYou mean the Consider / Don't Consider? If you have to use such piece of text, then unfortunately no. Perhaps you could try something else: In your table you could have a cell where you type a 0 or a 1 to turn on consider / Don't Consider instead of having it written out as text? Remember acad's tables aren't perfect. They're a far cry from a true spreadsheet. Perhaps you could use the xlsx file and copy-link-as-acad-entities instead. Then your xlsx file is doing all the formula calcs, and the link displays the spreadsheet portions as tables in acad. Quote Link to comment Share on other sites More sharing options...
wrha Posted May 30, 2013 Author Share Posted May 30, 2013 Exactly that what i do Quote Link to comment Share on other sites More sharing options...
